new setup quistions
Old Feb 12, 2006 | 07:25 PM
Q8CamaRo's Avatar
Default new setup quistions
`m planning to build a 347ci engine
mods
1-d1sc 15 PSI
2-Patriot LS6 5.7 - STAGE 2 2.055/1.57
3- FAST 90/90
4- 60 injectors + highflow fuel rails
5- 255 fuel pump
6- diamond pistons -8cc valve reliefs
7- eagle 6.125 connecting rods
and other valvetrain parts...
how much power should i expect??
what is the best compression ratio that would give the best power
thanks in advance
fahad
Old Feb 12, 2006 | 08:07 PM
98turbls1's Avatar
With a SC I would stick with 9.0-9.5:1....With this setup you could probably reach the 700rwhp mark or maybe a tad higher if you push it...tuning, tuning, tuning is the key!!!
Old Feb 12, 2006 | 08:09 PM
98turbls1's Avatar
YOu in the Army?? Camp Victory...Al Asad here man...hahaha..this place sucks!!!!
Old Feb 12, 2006 | 08:22 PM
Q8CamaRo's Avatar
yeah i`m an army man from the kuwait national guard "seargent" , i`m in the USA embassy
wich combustion chamber should i have?
Old Feb 12, 2006 | 08:29 PM
Q8CamaRo's Avatar
Old Feb 12, 2006 | 08:31 PM
98turbls1's Avatar
I would stick to the safe 72cc if they offer it...I'm pretty sure that they do but if not then probably the 67-68cc...Ohhhh so you're originally from Kuwait?? Or you're in the Embassy in Kuwait?? I"m confused...hahaha
Old Feb 12, 2006 | 08:41 PM
Q8CamaRo's Avatar
kuwaity ,, thanks for your help 72cc 6.0 heads from patriot ,, tom izzo from ls1 speed inc, told it will give 9:1 CR
fahad
Old Feb 13, 2006 | 05:12 AM
EPP's Avatar
EPP
I'd shoot for a 9.0 to 9.5/1 compression ratio. You're going to need dual Walbro in tank pumps. I'd also use a Nick Williams 90mm throttle body instead of the FAST 90mm. You're too far away to have to settle for the problems associated with the FAST throttle bodies, and sending them back until you get a good one. Bob
