can this piece be purchased?
Old Feb 20, 2006 | 12:17 PM
MIGHTYMOUSE's Avatar
Originally Posted by half-n-half
hmm...maybe i will get the T88 and try it out....i guess there is nothing to lose by going too big. does anyone have any pics to compare actual size of a t76GTS to a T88? of course though the T88 is most likely going to spool a little slower.
Thanks
Louie
the pte 88 will spool noticeably slower, be heavier and take up more room
if your goals are not over 900rwhp (manual trans) its easier all around to do the 76mm
Old Feb 20, 2006 | 03:59 PM
half-n-half's Avatar
well then, that settles my internal conflict regarding that.
Thanks
Louie
Old Mar 8, 2006 | 08:38 PM
ok guys just thought that i would mention that i went ahead and built the pipe i was asking about...
Old Mar 8, 2006 | 11:42 PM
code4's Avatar
I'm getting ready to do the same thing. How are you going to do the wastegate? I was thinking of using the piece in the link below & machining a hole in it for the WG pipe. It's a 3" pipe into a T4, maybe you loose some efficiency?
http://store.racing-solutions.org/3tot4tr.html
Old Mar 9, 2006 | 11:03 AM
i cant imagine that piece being much of a restriction...butyou will still mostl ikely have to get two pipes together and then into that one 3 inch...so i dont really see the point to it...
Thats just me though.
