Which gaskets and bolts for heads for boost ??
Old Feb 23, 2006 | 03:34 PM
kp's Avatar
kp
Originally Posted by SUPER DAVES Z
you can use the re-studs and their suppose to hold a little better. The bolts "should" be replaced after one use.
Stock bolts should be replaced after each use, ARP head bolts can be reused as many times as you want.
Old Feb 23, 2006 | 03:57 PM
SUPER DAVES Z's Avatar
cool, didn't know that
Old Feb 24, 2006 | 06:52 AM
Typhoon#1600's Avatar
the SCE TITAN ICS is a copper O-ring head gasket, available in various thicknesses, and also does NOT need to have the head/block machined for the o-ring. I was told by my machine shop that the Cometics are a great gasket, but the mating surfaces must be surgical - perfectly flat and clean, or you are going to have problems. They have run many engines with the Cometics, but loved these SCE's I brought in for mine. Says they look like they'll hold some serious boost.
Old Feb 24, 2006 | 08:17 AM
TwnTrboCE's Avatar
GM MLS gaskets are cheap and have held up well in high boost also. I run 26psi and I know Harlan has been near or at 30psi with them. I ran the same set all last season.
We run the stock metal exhaust manifold gaskets. No leaks and can be reused many times.
Old Dec 9, 2006 | 12:51 AM
1dirtyZ's Avatar
can the GM MLS gaskets be used on an o-ringed block?
Old Dec 9, 2006 | 09:07 AM
Jammer's Avatar
I run l-19 Arps, but cant say they are worth the 4-500 bucks or not....just a profit center for ARP or a saefty net for me...Dunno.
I also use Fel-Pro graphite head gaskets and they have seen 22lbs... I use these because my heads are O-Ringed...but block doesnt have reveiver grooves.
Stock ex mani gaskets here too.
Old Dec 9, 2006 | 09:47 AM
TwnTrboCE's Avatar
You can use the GM MLS gaskets with O-ringed heads and no receiver. I've been doing it for a couple years. A buddy of mine runs the same thing as well. No issues.
Old Dec 9, 2006 | 10:01 AM
prostock_bigblock's Avatar
I am curious to know if anybody runnin a 0.065 cometic gasket with the lq9 heads.
Old Dec 9, 2006 | 05:45 PM
Jammer's Avatar
Thats awesome info..thanks bro!
Old Dec 10, 2006 | 09:22 AM
1dirtyZ's Avatar
great , will be swapping them tommorow!
Old Dec 10, 2006 | 11:42 AM
Packy's Avatar
Originally Posted by DJ's99SS
What exactly is wrong with the ARP head bolts and "cometic gasket" combination? Curious becuase thats what I'm using on my stroker. So the the 6.0 head gaskets would be a better combo under boost?? The exh gaskets are required also for a "boosted" motor?
I don't know but I had a Cometic crack on me 1-2 cm allowing coolant to spill in off of #4 once. After that I switched to the GM MLS head gaskets and ARP bolts.
