2 small gates vs. 1 big gate
Old Feb 23, 2006 | 01:39 PM
MIGHTYMOUSE's Avatar
Default 2 small gates vs. 1 big gate
currently have an innovative pro gate (42mm) (10# spring) & PTE-88
with the gate direct to the turbo i get 13psi immediately and creep to 19psi
with the muffler off it goes as high as 24psi.
should i redo everything and plumb in a second pro gate?
should i keep the current mounting position and up to a 50-60mm single gate?
should i sell the pro gate and get like two 38mm tials or turbosmarts etc.
motor is 6.0L and i would like to control the boost down to 10psi flat across to 6800rpm.
thanks.
Old Feb 23, 2006 | 01:55 PM
Phate's Avatar
I am going to be using two 48mm Turbo Smart gates on my setup. Jose assures me that I will be able to control low boost very well.
Old Feb 23, 2006 | 02:58 PM
i was just talking to george at turbotech and he is favoring a single new gen w/g to try. that one is somewhere int he neighborhood of a 50mm valve i believe but the valve gets out of the way of the air.. which is pretty significant for flow.
http://www.turboneticsinc.com/valves_newgen.htm
Old Feb 23, 2006 | 03:28 PM
Wet 1's Avatar
thanks.
David,
I'd think any of the options you listed would get you were you want to be. I like the dual WG idea myself... but you might want to go with a large single since it would be the easiest route.
Old Feb 23, 2006 | 03:34 PM
yea way way easier.
anybody currently have a turbonetics new gen on an ls1 by chance?
Old Feb 24, 2006 | 05:21 AM
smokinHawk's Avatar
i think parish8 does.
Old Feb 24, 2006 | 08:27 AM
onfire's Avatar
Coal Mining Director
thanks.
Is this creep with EB turned off?
Old Feb 24, 2006 | 10:59 AM
any configuration.
Old Feb 24, 2006 | 11:31 AM
JZ 97 SS 1500's Avatar
LS1TECH Sponsor
Yes we have one on a LS1. Works good, but no better then what we are seeing with cheaper gates like the pro gate and new bigger power gate.
Jose
Old Feb 24, 2006 | 01:56 PM
Boostaholic's Avatar
I have no problem with twin 44s but then again my turbo setup is quite a bit different.
Old Feb 24, 2006 | 03:10 PM
KAOS's Avatar
i tried two gate once and couldnt build boost at all. now needless to say im a retard but it didnt work for me. went with a single progate now. hope it works
Old Feb 24, 2006 | 03:17 PM
Slowhawk's Avatar
LS1Tech Sponsor
On Purevils car we run 1 TIAL 44mm with the T88 and when boost even set at 8lbs it will hold it the entire rpm range.Of course it is vented directly to the ground.
