boosted spark plug help
Old Mar 4, 2006 | 05:34 PM
84camaroturbo's Avatar
i have the eldelbrock e-tec heads and i run ac-delco fr1lls. havent had a problem with them i run 13psi at 8.5 to 1 compression. i used to run the tr-6 bu tran into the same gasket problem.
Old Mar 6, 2006 | 03:51 PM
MIGHTYMOUSE's Avatar
behold the ngk r5672a-8 (7173) man tr-6 was a lot easier to say
results after dinner
Old Mar 6, 2006 | 09:23 PM
LTLHOMER's Avatar
What is the P/N for the tr6's? Is it 4177? I was running the AR3910's but they load up pretty easily and they're twice as expensive as the tr6's...and no one seems to have problems with the tr6's (I'm running stock heads) so I think I want to go that route.
Old Mar 6, 2006 | 09:57 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
When my All Pro heads show up, I'll compare TR8's with 3911's.
Old Mar 6, 2006 | 10:05 PM
ltl, the 3910 is a really really cold plug.. 3 heat ranges colder than the tr-6. but i agree that if you have stock cone seat heads that is the plug i would run.
tr-8 and 3911 are probably pretty darn close, exept the tr8 has a full tip and a cone seat.
anyways the new plugs work, but no better than the 3911's i was hoping were worn out. oh well trying something else now..
maybe get the valvesprings checked, maybe get someone else to try my injectors..maybe buy injectors.. maybe throw some money at a new cam/crank sensor
Old Mar 6, 2006 | 10:25 PM
LTLHOMER's Avatar
Are you saying to run the 3910's or the tr6's? I was planning on sticking with the tr6's since I've seen a lot of guys including yourself have good luck with them...and I am not pushing my setup very hard for awhile.
Old Mar 7, 2006 | 06:40 AM
im saying you should be great with the tr06 but since you've been running a much colder plug than that (the 3910) just keep your ears open, i dont know how agressive you have it tuned.
Old Mar 7, 2006 | 09:47 AM
1936FordPU's Avatar
Im really surprised you are using an extended tip plug.....
Old Mar 7, 2006 | 09:51 AM
1936FordPU's Avatar
Just for the record...The box does not say TR-8 on them....It will say TR-6 on the 4177 box however. You are giving misleading information. I may be wrong here but I also do not run anything that says TR in front of a number. TR=Terrible Race...IE extended tip plugs. I use the recessed porcelain style plugs with gasket seats. Part number for them is this: R5671A-8
Old Jun 21, 2006 | 09:52 PM
Yellowsierra's Avatar
Im using the Allpro heads and didnt even realize they used gasket plugs. Ive been using Tr6's for the past 2 months.
Old Jun 22, 2006 | 06:42 AM
you will likely have some trouble starting the new set of plugs now that the threads are smashed from the taper seat... who didn't tell you?
Old Jun 22, 2006 | 09:14 AM
  #32
LS1Tech Co-Founder
So Dave, you still run a set of AllPro's and run what plug?
Old Jun 22, 2006 | 09:46 AM
  #33
1936FordPU's Avatar
THey make spark plug thread chasers...takes about 15-20 minutes to chase all the threads.
Old Jun 22, 2006 | 10:16 AM
  #34
Lethal Injection's Avatar
Chase the aluminum shaving where??? Into the cylinder??
Old Jun 22, 2006 | 10:21 AM
  #35
Rick@Synergy's Avatar
Maybe I missed it, but I didnt see anyone talk about the BR7EF NGK plug. I run this one alot with high nitrous and blower cars. Works awsome.
Rick
Old Jun 22, 2006 | 10:27 AM
  #36
MrDude_1's Avatar
some sticky grease on the flutes of the tap will catch 95% of the shavings.... but yea.. into the cylinder....
Old Jun 22, 2006 | 11:06 AM
  #37
ngk r5672a-8 (7173)
Old Jun 22, 2006 | 01:24 PM
  #38
Bob didn't tell me about having to use gasket plugs. The heads are fine and I ordered the (7173) from summit last night along with a few other parts...
Old Jun 22, 2006 | 01:31 PM
  #39
LS1Tech Co-Founder
Which heads require gasketed plugs, and why? What does the gasket do?
Old Jun 22, 2006 | 02:07 PM
  #40
MrDude_1's Avatar
if the head has a tapered cone seat where the plug goes... it uses the tapered plugs like TR6s. the tapered cone is how it seals.. like an AN fitting.
if the head has a flat surface, perpendicular to the plug threads, then it uses a compression gasket spark plug... the gasket crushes to seal the plug...
