Big Chargecooler
Old Mar 5, 2006 | 12:17 PM
stevieturbo's Avatar
Default Big Chargecooler
Found this on another forum I use...
Its Craig Munro's Commodore from Aussieland. It used to be a Supercharged LS1 once, but now its Twin Turbo, and I suspect it might be pretty fast...
With a rather large and complicated chargecooler setup.
http://www.are.com.au/Big%20HP/Craig...sAWComorig.htm
Old Mar 5, 2006 | 12:25 PM
JZ 97 SS 1500's Avatar
LS1TECH Sponsor
Lots of un-needed weight and space taken up. A simply well thought out cooler or stacked cores with proper work would have achieved the same and be tons lighter.
Old Mar 5, 2006 | 12:27 PM
That water tank in the rear is hige, and must add some serious weight.
Really does seem OTT.
Old Mar 5, 2006 | 01:53 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
AU stuff always looks sharp. But is that car about 5000 lbs with driver?
Old Mar 5, 2006 | 02:20 PM
Doubt it would be that heavy. I know a stock 2 door Monaro ( GTO ), which uses a similar platform as the Commodore would be close to 4000lb with driver.
Kerb weight according to owners manual for a Monaro is about 1690kgs which is about 3720 lbs.
