Boost lower than usual
But if I add a boost controller, it will allow the boost to peak higher? I guess I have it backwards??? How have I tightened it and reduced my boost?
Here's a little bit about how they work
http://www.boostcontroller.com/display_page.php?i=22
Hope this helps.
later,
Dave
But I would be very careful becasue most of the time, if you turn a **** on a BC clockwise, the boost will go up. And unless you are paying close attention to the gauge, it could easily result in a damaged motor.
But yeah, strange, huh? I know it for a fact because it took me forever, driving/looking at the gauge, moving it a tiny bit, etc. to get it back to 7, 8 psi... After having closed it, though, it did entirely shut of all boost... I mean, WOT and it would get MAYBE 1 psi...
Thanks for the low-down.
So you DID pressure test the intercooler?
WTF?!?
Good ****, but... wow, sucks you went through so much!
But that still leaves the question... If that was never messed with, how did you lose boost to begin with?
