How quick are PT-88 guys running?
#41
Originally Posted by NA$TY-TA
When do we know more......
SSblack98,
FYI the GT42 is a 5" also..... mine is 5" off the turbo stepped down to 4"
Kyle
![Devil](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_devil.gif)
SSblack98,
Kyle
I was under the impression that the PT-88 utilizes a 4" DP...correct me if I am wrong here...
#43
LS1TECH Sponsor
#47
7 Second Club
Location: Grove City Ohio/Port Washington L.I sometimes
You could keep the 88 you have right now and learn how to drive a fast car,then upgrade to a bigger one when you get comfortable.
You could sell your 88 real quick like on your site without losing much money when the time comes to upgrade.
I plan on running a 94 right now and will put a 101 on after I get 50-60 passes in,or when I get bored with 7.40's.
I hear that a big turbo and little tire can be a handful to drive,especially for someone not used to it.
#48
Originally Posted by PurEvl
yep t4 pt88 14.5 psi on 93 pump was over 800rwhp...we just finished up the victor intake and the dual a600 pumps and are putting in the 75lb injectors in. See what this gained me an possible push 16psi for the street.
im sure it'll be a handfull, but anything more then a handfull is a waste, good thing you like to be wastefull.
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
so when do i get a ride (does it have a passenger seat?
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
#49
LS1Tech Co-Founder
1000rwhp with a 3400 raceweight will be a lot of fun. Your 96's will support 1000rwhp, just starting to get maxed out.
My turbo can make more power, but I'm not looking to push it that hard for a while since I don't want to find the limits of my shortblock early in the season... Plus the sub 8.49 cage rules require a bit of reworking for me.
#50
7 Second Club
Originally Posted by smokinHawk
have you checked you back pressure?
You'd probably chit yourself by the top of 2nd gear anyway.
#51
#53
LS1TECH Sponsor
Addressing bacpressure starts on the exhaust side. Making the engine breathe even better will make it worse actually. The further the PR gets away from 1:1 the worse it will get and the more hp you will lose.
#56
LS1TECH Sponsor
Originally Posted by B18B1LS1
I believe Brent over on turbomustangs.com make a bit over 1200 rwhp on his Majestic T4 88 302 combo, with a 5-speed though. Not sure on all the specs of the Majestic and he is way smaller on the cubes, so maybe my post is irrelevant!
Jeffrey
Jeffrey
Brent is running a TV series 88 with a T6, not T4 last I checked. Its based on the TV81. We built one for one of the TM members using the same core. Turbo is nice and will make some power. Also is made 1049rwhp...
http://www.turbomustangs.com/smf/ind...?topic=35938.0
#57
Originally Posted by Nine Ball
Okay, back to my original question. Anyone actually racing their PT88 cars, or just dyno racers?
I believe Parish made 1100 rwhp on his PT88., if it can take his land yatch/truck into the 10.2s? imagine a light fbody
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
#58
Originally Posted by RyanJ
PT-88 = T4 and I think that will be your limitation. I see high backpressure in your future (if you are serious about pushing the limits of the turbo, especially with 408cid). If you are building your own kit anyway, T6 is what you need for sure...unless you do twins. I mean its a race car, right? Nut-up and put a 91mm+ on the car like 'Wormboy'.
BTW - 88mm is the size of the wheel, the case its in can vary in size (within reason). Obviously, the bigger the turbo the higher the ceiling, but there are exceptions. You have the money I think...call Jose and just have him build you one.
![Driving](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_driving3.gif)
#59
Originally Posted by JZ 97 SS 1500
Here is a quick reference...
The two in the middle are the PT88 and GT47. PT88 is the smaller![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
Also the GT42 vs GT47
![](http://forcedinductions.com/images/turbos2.jpg)
![](http://forcedinductions.com/images/turbos3.jpg)
#60
You made me doubt myself so I had to go dig it up! Almost 1200 rwhp on a T4 88, but not quite!
http://www.turbomustangs.com/smf/ind...?topic=37521.0
Sorry Tony, back on topic now!
