Turbo question help please?
Old Mar 12, 2006 | 10:37 AM
SSilverSSurfer's Avatar
Default Turbo question help please?
right now i have the s cam on a 113lsa....and im researching everything for my FI setup...just curious what a good turbo cam would be....and also would the car make good power with a newar stock cube motor or should i go big?
Old Mar 12, 2006 | 12:08 PM
Smearin's Avatar
ANything in the 115lsa range would be a good cam.. Im sure some of the turbo guys could chime in..
You can make very good hp on a stock cubed block.. more than is usable on the street
Old Mar 13, 2006 | 12:49 AM
cool.....i wanted to stay around a low cube and not a 408 or sumthin like that
Old Mar 13, 2006 | 01:16 AM
Spenser309's Avatar
woo dont blindly take the 115lsa thing. the reason people say that is because it stops u from having alot of overlap that you dont need for a turbo.
Your gonna need some exhaust duration also, and maybe shorten the intake because you dont need the same time to get the air in the hole. I'd reccomend calling a sponsor, W2W or Stenod are really good for FI Questions, because IM NOT A MECHANIC But i do read alot.
Old Mar 13, 2006 | 10:51 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
What are the specs of the S cam?
Old Mar 13, 2006 | 10:53 AM
238/242 .605/.610 113lsa
Old Mar 13, 2006 | 10:57 AM
LS1Tech Co-Founder
Single or twin turbo?
Old Mar 13, 2006 | 11:10 AM
single....or maybe even a d1sc....cant decide....i was lookin for some input on this from ppl
Old Mar 13, 2006 | 11:32 PM
JZ 97 SS 1500's Avatar
LS1TECH Sponsor
With that cam, if you plan to run single, it better be an efficient setup. IF backpressure is high, you are risky potential reversion, holding the exhaust valve open that long.
Old Mar 13, 2006 | 11:43 PM
well i didnt plan on using that cam if it wasnt good enuff
