how to install a oil catch can on a procharged LS1?
But i am not sure which line to tap into,
i was thinking the one that goes from the procharger inlet hat to the passenger side valve cover,
And can someone explain how the new Procharger PCV system works.
Thank you
On the crossover from the drivers side valve cover to the passaner side I took the Y off and added some hose to connect them. Basicly it just loops over. Then I capped off the valve cover to TB.Went to macmaster and ordered part # 7775K52 www.mcmaster.com You will add the mcmaster check valve to the intake from the catch can. Run any catch can you want. I did convert to a LS6 valley cover for extra help. And I topped it off with a breather off the oil fill.
but where is your line coming from to the catch can and where does it go after the catch can,
does it come from the Prochargers inlet hat ,
Please help me out
thank you
Please help me out
thank you
This worked very well on my buddies setup that I did for him. His dipstick was blowing out and oil was everywhere
Fixed it and it worked like a champ.
