what is a best cubic inch and Turbo ???
Old Mar 16, 2006 | 09:33 AM
NAVY's Avatar
Default what is a best cubic inch and Turbo ???
I was wondering what would be better on my setup,my motor is going to be a built 346 or 371 ci ??
my friend say T70mm its a good for street, pls i want opinion my friends .
what is the best T??? and ???ci ?
thank you
navy
Old Mar 16, 2006 | 09:52 AM
GTFORMULA's Avatar
Well thats a hard one to say, but from what ive read for the past years is that for a mild setup a 346 is more than enough. For a more race setup 6.0 iron block at 370 cid is best. The t 70 will be good for the street and spool pretty quick with 346 cid. Thats just my opinion.
Old Mar 16, 2006 | 09:55 AM
white2001s10's Avatar
The relatively slow burn rate common to a "turbo tune" is better matched to a slower piston speed such as what you would get with a short stroke /big bore engine.
Aside from that you want to look at your desired RPM range. A given set of heads will be more efficient at higher RPM on a smaller cube engine. The same set of heads would be efficient at a lower RPM on a larger cube engine.
A longer stroke crankshaft tends to move efficiency and power down in the RPM range a bit.
With these being general truths, an example of a mismatch would be a small turbocharger on a large cube stroker engine cammed for making power at very high RPM, and using a close-geared manual trans.
Turbo sizing depends a lot on your transmission type and what you want the car to do. Low RPM automatic trans applications may run better with a turbo on the smaller side, where a higher RPM manual trans would do better with a larger turbo. I think it's best to talk to a turbo sizing expert about picking the right one, and be honest about what you want the car to do.
HTH
Old Mar 16, 2006 | 09:57 AM
dynedta's Avatar
chronic masturbator
there are too many variables in this question how much power are you wanting to make? daily driver or race only, I would say for a street car the turbo reguardless would be a t76gts, but engine wise its up in the air, are you worried about the extra engine weight etc
Old Mar 16, 2006 | 02:39 PM
TeeKay's Avatar
Well, guys, this isn't a definitive answer, just a point of data. I've got a 383 stroked LS1 that I went to Moore for cam specs. they recommended 224/228 @114 with .580 lift. So I go to the various web sites for info on turbos and performance and wound up doing a plot of my 383 on a T76 compressor map. I plotted various boost levels vs. rpm for the engine. A 371 would show a little better efficiency on the graph. Here's the map as I plotted it. Draw whatever conclusions you think appropriate. I'm going with the T76 based on what I just said and the graph. HTH
OBTW, 75 pph (bottom of the graph) should make about 815 crank hp or about 650 rwhp.
Attached Thumbnails what is a best cubic inch and Turbo ???-t76_383mapsmall.jpg
Old Mar 16, 2006 | 06:45 PM
engineermike's Avatar
My 383 made 30 more rwhp than my current 363, both at 13 psi. It may be more efficient on a smaller motor, but it efficiently flows less air.
Old Mar 16, 2006 | 06:54 PM
NAVY's Avatar
thank you ool for your opinions and im going 371ci i think its a good machines.
* this is my parts :
i know im not forgetting my turbo kit
PTS LS1 Camaro Single Turbo System -
* Turbosmart Manual Boost Controller -
* 1600* Silver Hot Side Coating
* (8) 55 lbs High Impedence Injectors -
* LS1 Air to Air Intercooler Upgrade -
* Snow Stage 2 Meth System (over 500hp) -
* Precision 70-GTS-H Turbo
* T-Bolt Clamp Upgrade (Std. On DR & Race Kits) -
* TiAL 50mm Billet Blow Off Valve -
* Poished Compressor Cover T04 -
* Turbine Housing Silver Polished Ceramic Coated
thank you
navy
Old Mar 16, 2006 | 07:16 PM
Smearin's Avatar
I would get bigger injectors.. Well actually it depends on the Hp you want to make..
I remember Armagedon making like 600 some rwhp with a 70 and his phamspeed kit on a iron 6.0
Old Mar 17, 2006 | 07:05 AM
NAVY's Avatar
ok i can change injectors so ,what is injectors size?
i want 600+ rwhp
thanks
Old Mar 17, 2006 | 07:35 AM
Blown SS's Avatar
Mototron 60's
Old Mar 17, 2006 | 08:34 AM
TeeKay's Avatar
Mike, you're right. Like what they say, no replacement for displacement. Just one small point though, the graph shows 6,000 rpm. If you wind the smaller motor tighter, you'll get more flow - and hp. However, you can see the way I chose - 383!
BTW, NAVY, GL on the 371. I think you'll be pleased.
Old Mar 17, 2006 | 04:49 PM
NAVY's Avatar
you mean 383ci its a best than 371ci.
Old Mar 17, 2006 | 04:52 PM
Smearin's Avatar
A 6.0 iron block would be a good choice.. lot of guys are running that with good results.. a 76 would be a good choice too, so that you have room to grow when you get tired of 600rwhp and want more
Old Mar 17, 2006 | 05:20 PM
NAVY's Avatar
I know im tired 600 and up you must be tired .
Old Mar 19, 2006 | 10:15 AM
TeeKay's Avatar
Navy, I had an LS1 aluminum block. Resleeving the aluminum block was not as reliable to me as stroking it. So the logical way for me to go was a stroker crank. At a 4" stroke with a 3.905 bore hone, it comes to 383 ci. If I'm not mistaken, you can go to the 6.0 iron block, keep the stock 3.64" stroke, and bore it for 370-371 ci without a problem. I just didn't have that option is all. So the project I've got is to turbo the 383. Not to worry, either one is a strong platform. I don't necessarily think one is better than the other since there's only about 3% difference in ci. GL.
Old Mar 19, 2006 | 10:32 AM
Navy David SS's Avatar
Navy. A lot will depend on what your goals are. BUT
Since you are going to bore and stroke anyway. Buy a 6.0L iron block shortblock. Keep your stocker or sell it. Iron blocks can be had for reasonably cheap. Use the stock 6.0 crank and bore .030 over. You'll have the 370. Make sure you have the block and crank checked out my a damn good machine shop. Buy your pistons and rods carefully. Don't skimp on the small stuff (balancer, oil pump,etc). If you're short on cash you can always use your stock heads for now. Upgrade your springs. This should give you a start. For cam, use one of our sponsors that specialize in turbos -- W2W is my choice. There is a lot good info on this site. Read some of the other builds going on.
Most importantly. Decide on your goals. Get your budget together and go for it.
David (oh by the way, I am a retired Navy YNC(SW) )
Old Mar 19, 2006 | 10:59 AM
SScam68's Avatar
I would call Jose at forced inductions (sponsor), they see this kind of stuff day in day out.
