Dyno Tonight! Any Advice?
Old Mar 18, 2006 | 08:34 AM
30th t/a's Avatar
wow! congrat on those numbers! what kind of setup are you running? heads, cam...etc?
ill bet you'll be damn close if not to the 130mph mark
Old Mar 18, 2006 | 08:36 AM
2000 ws6's Avatar
Wanted to limit rpms on a stock bottom end is why we shut it down at 5600. No point in going much higher than that on the stock bottom end with that much tq.
Old Mar 18, 2006 | 09:28 AM
KAOS's Avatar
mods are as follows:
single turbo kit fabbed by john pham using STOCK truck manifolds and t74
stock 6l heads
stock 98 cam
918 springs
ls6 intake
spec 3i clutch
racetronix fuel plug and play with 55lb siemens
wolfe chromoly 6pt
thats about it. a few little things here and there but other than that, that is it. probably going to turn it down to around 8 psi just to be safe. but man its fun. i would love to see 130mph but i doubt it the way it spins. if i can find some big slicks or big drag radials just to get me movin that would rock. but we will see
Old Mar 18, 2006 | 10:29 AM
PurEvl's Avatar
stock cam is my guess
Old Mar 18, 2006 | 12:02 PM
rod442's Avatar
should have run it higher on the dyno to make sure it was spot on up top. I spin mine to 6700 at the track to make it through the traps. (in 4th) still shift at 6000 tho.
and unless its totally off I guess 11.8's at 123-4 if on nitto's. a better tire, maybe 11.3,4's at 125-6.
street tires? forget it. I have run as bad as 13.3 at 117, cause of spinning so bad. or on a fully prepped stanton track (which hooks well), 12.0 at 124, lol.
Old Mar 18, 2006 | 12:39 PM
NA$TY-TA's Avatar
Bad *** man.... congrats.....
Old Mar 18, 2006 | 01:16 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I'm thinking high 10's with a little traction, and mph around 133... just a guess. Was that on 93 pump, no meth?
Old Mar 18, 2006 | 01:25 PM
30th t/a's Avatar
"92 octane, all i could find. no meth. probably goin to turn it down some. at least a pound or so. holds steady right at 10. finally got to do some racing as well. raced a 10sec 5.0 and pulled about 5 cars or so, spinning all the way through 3rd. its a great runnin car and that makes me feel good about this project. max afr was 11.5, most of the time it was 10.9 thru 11.5 so its a pretty safe tune. still got a little something goin on at idle but it didnt affect performance at all. 510ftlbs at 3700 rpm max at 4500 596ftlb. max hp was at 5500 with 578.9 and 551tq to boot. all runs ended at 5600rpm. cant wait to see how it does at track 13.0@120's? maybe we will see"
__________________
Old Mar 18, 2006 | 07:23 PM
LS1Tech Co-Founder
#'s are really impressive, basically a stock engine but with 9.6:1 compression or so.
Old Mar 18, 2006 | 07:32 PM
BLWN1's Avatar
So are you getting the fever again yet...?
Congrats on the numbers!
Old Mar 18, 2006 | 08:31 PM
solobaric's Avatar
Congrats Kaos! Glad to see things are finally working out for you bro! Good luck at the track and let us know how it goes at the track!
Old Mar 18, 2006 | 08:34 PM
  #32
frcefed98's Avatar
Wicked numbers for your mods. Man I'd be itching to turn it up a lil more
J
Old Mar 18, 2006 | 09:03 PM
  #33
LSs1Power's Avatar
Nice numbers... Post the dyno sheet.
Old Mar 18, 2006 | 11:33 PM
  #34
KAOS's Avatar
sheet is in the dyno forum. let me know waht ya think. peeks late i think but you cant do nothing with it now let alone if it came in any sooner
