Oiling/electrics/WG and BOV ?'s
Old Mar 17, 2006 | 01:17 PM
WestSide's Avatar
Default Oiling/electrics/WG and BOV ?'s
First off, I'm underway with putting a phamspeed kit on my car. precision t76 sitting in front of the crank pulley.
Oiling the turbo... I need a -10an hose for the drain, and a -4an feed, right? Where can I get these and can I get certain lengths? I believe gravity drain will do just fine. I also need to know what fittings to get for the oil pan drain and feed. BTW, I have no idea what an and npt stand for.
Electrics...I have a permacool single 16" fan that pushes through the radiator. Do I wire it up in parallel?
WG and BOV. I know where to put these, dunno about the lines. I have a tial 44mm wg i believe, and a tial 50mm bov. Where do I tap for vaccum sources? Do i need a diff. pressure sensor? How are the lines routed? Where do I get the lines?
I know this is a lot of questions at once, I appreciate any replies.
