Making progress on phamspeed kit
Old Apr 1, 2006 | 02:59 PM
Dr.x's Avatar
coming along pretty nice westside
Old Apr 2, 2006 | 11:44 AM
smokinHawk's Avatar
wow is the alternator installed right, i dont rememer those type being that close to the oil filler neck? are you going to have to remove the alternator to add oil?
i know his manafolds veried quite a bit from make to make, but did his brackts?
did you have to take the filler neck off and just use the cap to get it to fit or did you do that for other reasons?
Old Apr 2, 2006 | 11:53 AM
WestSide's Avatar
I don't see how else the bracket can be installed. I've tried mocking it up everyway that I can...FrceFed said he had this problem as well. I can get the oil cap off without taking the alt off. Will your bracket even let me close my hood? Looks really high from the picture
Double checked the pullies and they're a rib off. hmm
Old Apr 2, 2006 | 12:00 PM
ddnspider's Avatar
that doesnt look right,i use the neck and then a breather,its clocked a bit,but it fits ok,id double check that.Send a pm to where u got the alt bracket and ask him for a few pics
Old Apr 2, 2006 | 12:34 PM
Mr_president's Avatar
wooow west side im impressed keep the good work up!! ANd nicce mandrel bent pieces!!
Old Apr 2, 2006 | 12:43 PM
WestSide's Avatar
It was a rib off but I added a washer behind the bracket and it lines up good now...the oil cap comes off easy now.
Old Apr 2, 2006 | 12:44 PM
make sure you get video of first start up!
Old Apr 2, 2006 | 06:10 PM
smokinHawk's Avatar
yes the bracket i have fits under the stock hood no problem.
at least you can take the cap off then, that sould suck if you couldnt.
so the filler neck wount fit withthat bracket though?
Old Apr 2, 2006 | 06:23 PM
WestSide's Avatar
Actually I dont think the belt can make the shot from the alternator to the crank, so I'll probably be making a paypal out to you soon.
I have the whole week off to finish up the odds and ends.
Got the cover test fit over the intercooler and it fits good even with the bumper support
Old Apr 3, 2006 | 04:20 PM
Dr.x's Avatar
looks good nice tight fit
Old Apr 4, 2006 | 07:32 PM
MattIROC's Avatar
looks great so far. cant wait to check it out and go for a ride. its going to be sick on the highway!!!!
Old Apr 10, 2006 | 05:25 PM
  #32
deviate42's Avatar
very kickass.
Im looking for a phamspeed kit right now.
Great pictures!!
when you get it all together, can you take one for ground clearence?
Old Apr 11, 2006 | 09:31 PM
  #33
black98ws6ta's Avatar
I have this exact same kit, in hot parts only form for sale in the classifieds. Dont mean to hijack, thanks.
Old Apr 12, 2006 | 05:52 AM
  #34
smokinHawk's Avatar
any updates?
id like to see your alternator mounted now
Old Apr 12, 2006 | 06:16 PM
  #35
WestSide's Avatar
Bracket should be here any day now. Got all of my oil supplies for feed/drain today though!!!
Old Apr 12, 2006 | 10:39 PM
  #36
frcefed98's Avatar
But I can get a breather on mine and still have access to the fuel rail
MY bracket is a lil leaner than the smokinhawk bracket and is a bit different than the pham/GZM thing as the pham one didn't work at all, I also had to shim the bracket out with a washer on each mounting pad on where it bolts to the tensioner to get the alignment right....
Post up more pics
Old Apr 12, 2006 | 11:11 PM
  #37
where can i get a flat side pullie for the alternator tesioner?
Old Apr 13, 2006 | 05:50 AM
  #38
smokinHawk's Avatar
air conditioner and the alternator bracket have one, think you can switch one of them out.
Old Apr 13, 2006 | 03:14 PM
  #39
frcefed98's Avatar
That has been replaced on mine with a 6 rib plastic/nylon idler pulley from NAPA, its "about" the same diameter and holds the belt in alignment better, not that I had any issues with the smooth idler, just got the ribbed one for some piece of mind...gotta take a new pic of that too
Old Apr 16, 2006 | 01:16 PM
  #40
WestSide's Avatar
