Making progress on phamspeed kit
Old Jun 11, 2006 | 08:27 PM
  #61
XpEdItIoUs's Avatar
Congrats on the successful install i just got my tubular phamspeed kit today hopefully it will go as good for me. Where did you buy the scavenge pump and where did you mount it.
Old Jun 11, 2006 | 08:33 PM
  #62
FUroundeye's Avatar
WOOT!!! Can't wait to check it out
Old Jun 11, 2006 | 09:06 PM
  #63
WestSide's Avatar
i bought the scavenge pump from a local speed shop, mounted it low at the bottom of the a/c compressor? it lays back on it.
I have a small startup video but I'm not gonna post it. I'm wearing a car quest sleeve less shirt and the crickets around here go crazy at this time...sounds like the jungle I'll get another one tomorrow, and pics of the pump mounted. My JB weld on the oil feed fitting melted
Old Jun 11, 2006 | 09:40 PM
  #64
MiaSSmaro98's Avatar
congarts,ur pics have help me out for future plans
Old Jun 12, 2006 | 10:14 AM
  #65
Dr.x's Avatar
Originally Posted by WestSide
SHE RUNS!!!!!!!!!!!!!!!!!!!!!!!!! Drove it around the hood today, FINALLY. Few problems...had the fan wired backwards so it overheated pretty quick. Fixed that...my JB weld the fitting into the oil feed elbow trick didn't work, so anyone know where I can find an extra elbow (right above oil filter)? Other than that, all I need is a filter for the turbo and some not-so-ghetto plug wires and i'll be happy for now
didn't you use a tap and drill for the for the feed elbow?I must of missed something
Old Jun 12, 2006 | 11:13 AM
  #66
WestSide's Avatar
I drilled it out about 1/16" too much, so when I tapped it the threads were barely there, so as a quick fix I just JB welded the fitting in there...didn't occur that JBW would melt Now the search begins again for a replacement elbow.
Edit - Found a new one locally, should be patched up tomorrow ready to terrorize
Old Jun 12, 2006 | 12:30 PM
  #67
Dr.x's Avatar
If that falls through let me know I have an extra one. I'm just waiting on auto meter to get my new wideband 02 sensor here so I can finally tune it I'll post pictures when I get a chance
Old Jun 12, 2006 | 01:49 PM
  #68
so were u can get pressure oil from u have to drill and tap?can u post pics?
Old Jun 13, 2006 | 05:38 PM
  #69
WestSide's Avatar
I went and bought a new cover, redrilled and tapped it RIGHT this time I do appreciate the offering though. Got that all patched up, put a ricer air filter on the turbo...took it for a spin, saw light smoke behind me so I pulled over and found 3 leaks. One at the inlet of the turbo (few drops), one at the exit of the scavenger pump, and one from the oil drain into the oil cap. Oh well, fix one problem, another few pop up. Gotta buy a boost gauge tonight too.
Do I need a restrictor? I'm running -4an to the turbo...
Old Jun 13, 2006 | 06:18 PM
  #70
west do u have a pic of what u have to drill and tap
Old Jun 13, 2006 | 06:54 PM
  #71
WestSide's Avatar
This is where I put my scavenger pump. Too much crap behind the radiator so I had to put it up above the air dam. Don't mind the ghetto ground
Oil return straight into the cap. I'm probably going to run it into the valvecover instead, gotta find a new cap and filler neck.
MiaSS, this is the fitting that you drill out and tap. It is directly above your oil filter, remove it and use a drill to drill out to whatever feed fitting size you use.
Clearance on the driver's side is lower but I can tweak it to get another half inch or so
Old Jun 13, 2006 | 06:58 PM
  #72
Mr_president's Avatar
video video video !!!! lets see it
Old Jun 13, 2006 | 07:32 PM
  #73
WestSide's Avatar
fiiiiiiiiiiiiiiiiiiine. ignore the sleeveless car quest shirt and the crickets. had an oil leak at the time so only a few seconds (forgot the cars wheels were turned so it's sitting funny)
Old Jun 13, 2006 | 08:02 PM
  #74
2002/Black/SS's Avatar
whats size is a g5 cam?
Old Jun 13, 2006 | 09:48 PM
  #75
thanks for the pic.but were do u actually drill it?and wats a good size hose for an oil supply to the turbo
Old Jun 15, 2006 | 08:08 AM
  #76
XpEdItIoUs's Avatar
What's the part number for the scavenge pump? also what wastegate are you running and whats the size.
Old Jun 15, 2006 | 05:38 PM
  #77
SierraSport's Avatar
Your Welcome Matt.. It sounded good and we need to get it over to the shop to get all that wiring mess a lil clean up.Im sure im going to go over everything to make sure we got everything .. Sorry it took me so long to get over to your place to get that wiring stuff done, glad it runs ..
Maybe we can start the Sierra Turbo Kit soon, if I ever get the funds together to start it ..
Old Jun 20, 2006 | 10:59 PM
  #78
Reject's Avatar
kick ***! just finished reading threw all of these pages, very impressive! now we need a video of the romping going on!
