View Poll Results: Which Turbo Setup Would You Choose?
STS
9
21.43%
GMR Single Turbo
32
76.19%
Multiple Choice Poll. Voters: 42. You may not vote on this poll
Which would you go with?
Old Mar 29, 2006 | 02:04 PM
Leo@GMRSPEED's Avatar
Suspended Sponsor
Originally Posted by rotweiler-ws6
500 RWTQ is pretty impressive. You've got me beat there. I believe my base rear-wheel torque came in at around 440ish and that was on a completely stock block (2000) with no mods whatsoever, other than the necessary 42# injectors - 5psi SAE on a dynojet. This was the first upgrade that I had done, actually. As far as the STS numbers go, I've seen slightly better numbers and slightly worse numbers on this board with other members but I think I was around average overall for the base kit. Oh, and that was also with the cheapie 60-1 turbo. Is that the same one that you use with your base kit or do you also offer upgraded sizes? I'm with you on the curiousity. I wouldnt mind a ride to compare...
Wow so kinda even things out if you want to look at it that way. Our car had more TQ your had more HP, but remember HP is how fast you hit the wall, Torque is how far ya take it with ya Just messing with ya. We used a similar turbo a T61 with 5psi. We do offer upgraded sizes [can be found under forced induction at www.gmrspeed.com]
-Leo
Old Mar 29, 2006 | 05:17 PM
Superman09's Avatar
LS1Tech Sponsor
Leo, on your single kit, without upgrading anything in the kit but the turbo,about how much power can the kit put out safely? Im hearing mixed views from some saying it max's out at 500 ish and anything above that is unsafe even to a forged motor, others saying 700 rwhp is possible with a bigger turbo. So about what can the kit do without upgrading parts besides the turbo? Thanks!
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
