WHAT TO DO TO PCV SYSTEM 4 Boost???
Old Mar 28, 2006 | 10:16 AM
fenix99's Avatar
Restricted User
Lightbulb WHAT TO DO TO PCV SYSTEM 4 Boost???
Ok guys im about ready to start my turbo setup almost got everything together. I know the stock PCV system cant be used for boost because the manifold has to be vented etc? the manifold cant be pressurized or the car will act crazy...
the question is what do i have to do to it, what do i have to modify, and whats the best most efficient way to take care of this pcv issue for my rear mount????? thanks all info. is greatly appreciated
Old Mar 28, 2006 | 10:38 AM
ty_ty13's Avatar
7 Second Club
im also curious because if will be going FI soon
bump TTT
Old Mar 28, 2006 | 10:40 AM
Smearin's Avatar
Run catch cans from each bank... Theres a pic here somewhere..
if i cant find it maybe someone will post it.
Old Mar 28, 2006 | 10:55 AM
fletchls1's Avatar
What if you just leave them vent? Maybe put filters on them?
Old Mar 28, 2006 | 11:03 AM
ABeasst's Avatar
you will just leak oil onto the exhaust and gets kinda annoying
Old Mar 28, 2006 | 07:52 PM
Darren P's Avatar
it does not just leak it blows out and makes a huge mess
Old Mar 28, 2006 | 08:31 PM
72firebird's Avatar
That's similar to how my TTA was originally routed. It had a tube that ran from the top of the valve cover to the intake before the compresser housing. Then it also has a PCV valve running from the bottom plate of the intake manifold up to the vacuum block on the throttle body. I replaced the tube that ran before the turbo because it caused a buildup of oil in the intercooler and decreases the efficiency of it. For now it's just been replaced with a cheapy filter.
Old Mar 28, 2006 | 08:36 PM
y2khawk's Avatar
simple thing to do is move the fresh air feed for the valve cover from the TB to the inlet pipe before the turbo and put a real check valve between the inlet to the manifold and the PCV valve itself.
If you can't get the fresh air inlet after the MAF and before the compressor you'll always have an unmetered leak that will drive you nuts chasing the idle fuel trims If you're running an SD tune it won't matter, you can just run a small filter on the inlet.
Old Mar 29, 2006 | 12:10 AM
89Formulaws6's Avatar
that was me that drew it thank you good to see someone saved my pic but noone looked for the post it was a huge post i made and i don't feel like retypeing everything as it was alot.
https://ls1tech.com/forums/forced-induction/470188-blow.html
i think it should be made a sticky as i covered everything in great detail on how to have a good running pcv system
also Y2khawk where in waterford are you? i am 20mins away and would love to see your twin turbo firehawk
Old Mar 30, 2006 | 12:54 AM
Silver02Z28's Avatar
Check valve on the PCV.
Old Mar 31, 2006 | 01:28 AM
KAOS's Avatar
now with that catch can does it need a filter. i was thinking if it did that would defeat the purpose, correct?
Old Mar 31, 2006 | 01:08 PM
i haven't seen one with a filter, but that doesn't mean there arn't some out there
