T-88 + built 346 Hp #'s??
I just wonder what you guys would say if you knew what was on my little 346 CID motor. But i don't want to get into a pissing match with everyone like last time. No one wants to listen to what i have to say. So i'm done telling you guys about it. You guys will see sooner or later.
also i dont think youll get compressor surge with 300-360 cubes
http://psj.ls1tech.com/gallery/main....b505e346460f29
car hits my full boost (11-12 psi) some where around 4000-4500, once the car gets in the 6k range the tach cant keep up and i tend to hit the rev limiter trying to rev it out close to 7k, this is telling me that between 6k-7k is making alot of power, as i can feel the car scoot.
i really think i need to rev it out more, and once i get my fuelling better i might take it to 7200 (already running 130 duty cyle on my injectors, but i think i can improve that by tweaking the fuel pressure) its just hard taking it down the track, exspecialy with the 3.73 gears and a 26" tire, im going through the gears way to fast.
the car definatly feels more powerful, more voilent then my old T76 tti kit (same engine), even off boost.
i think back pressure might have restriced the engine at lower off boost levels or something, the transistion to boost now doesnt feel so noticable, like it just doesnt reach the boost thresh-hold level then goes, now it just revs out from low rpm then once it hits 5k i have about a second or less to shift before hitting the limiter at 7k
the power band is more peaker then my old 76mm turbo
http://psj.ls1tech.com/gallery/main....m&g2_itemId=10
and yes a T4 one is easier to package, mine aint to bad.
