Wideband o2 location for remote mount??
"Not the pressure side, as that will screw up the lambda reading. "
Incase you didn't understand, the pressure side is every part of the exhaust that is BEFORE the turbo. That is, all the way from the engine to where the exhaust hooks INTO the turbo. There is actually pressure in there that is comparable to the psi you see in the intake.
If you mount the sensor there, it will undergo extreme pressure/heat which will screw up the reading and possibly ruin the sensor.
It is not rocket science. JUST MOUNT IT AFTER THE TURBO. Like TIM Z said, 8 inches after is a decent spot.
LM-1 Documentation:
On TURBO CHARGED vehicles:
- 6 -
Bung: Install the bung downstream from the turbo before the catalytic
converter. The high exhaust pressure before the turbo interferes with
the lambda measurement and the high exhaust temperatures
encountered there can damage the sensor.
LM-1 Documentation:
- 6 -
