Wideband o2 location for remote mount??
You can mount the 02 bung in the exhaust pipe that comes out of the turbo. Not the pressure side, as that will screw up the lambda reading. Also, try to mount it at either 3 or 9 o'clock on the pipe.
Also, I thought this was obvious, but try to place the sensor not too close to the outlet. You dont have to have it directly after the turbo, but somewhere close can't hurt for a possibly more accurate reading. But at WOT, there is so much airflow that you probably wouldnt tell anyway.
I would think the y-pipe junction would work fine. Nothing happens in the turbo to change oxygen content.
Jim
"Not the pressure side, as that will screw up the lambda reading. "
Incase you didn't understand, the pressure side is every part of the exhaust that is BEFORE the turbo. That is, all the way from the engine to where the exhaust hooks INTO the turbo. There is actually pressure in there that is comparable to the psi you see in the intake.
If you mount the sensor there, it will undergo extreme pressure/heat which will screw up the reading and possibly ruin the sensor.
It is not rocket science. JUST MOUNT IT AFTER THE TURBO. Like TIM Z said, 8 inches after is a decent spot.
