People that have installed Victor Jr Intake....
Sorry to hijack your thread..
I currently have a LSX that I was going to use, but I would rather use a Victor Jr type intake that I can use with my NW 90mm. I dont realy want to have to modify anything or have it not sealing properly, so what route should I go with? I was going to try Aarons setups, but it sounds like there are some minor issues. What would you guys use if you had to do it over again?
Flossin' twin turbos
Originally Posted by CHarris
You could also just mill the face after welding to help it square up again.
If the TB surface is warped... how about the flange that attaches to the intake?
LS1Tech Sponsor
For the 2 intakes I did nothing was really bad.The injector's just needed to be lubed good to go in the intake with some good pressure and wiggling.I just used a paper gasket and tightened the 4 TB bolts first to sit it flush,then snuged the top one which is pretty much there for looks.
LS1TECH Sponsor
damn you did take everything apart....lol we need that 3 bar sensor and I am ready to tune....
Originally Posted by Tiago
I used Aaron's Elbow Too... had to cut out some of the Cowl but not a big deal...
I have a couple of other issues still.
The throttle body flange on the elbow doesn't seem to be flat? look at the pictures attached.
I compared the Speed Inc rails to the Edelbrocks and the angle of the injectors are the same, so wtf they wont stab in I don't know, stuck there![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
I will make custom brackets for teh rails if neeedd be.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
I'm looking for the 3 bar also. Are you going to use the one for the 89 TA or the newer one Delco is suppose to have thats plug-n-play but may not be available just yet. Any info will help...Thanks!
Originally Posted by DJ's99SS
Another thread jacker, sorry...
we will be using
12223861 - 3 Bar MAP sensor
15305891 - pigtail harness
LS1TECH Sponsor
hahaah not thread jacking tiago needs to fab some parts for me...
Dont worry we will post everything on tiagos III bar tuning .......and I just felt like teasin him.
#32
Originally Posted by Exotic Performance Plus
Another thread hijacker... Tiago, I sent out your parts today. Did all 50 pages of the ATI instruction manual make it through your fax machine? Bob
#33
eh?
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
Bob, I think you may have me confused with someone else
#35
Closed ex-Sponsor Account
I know Nitrous Outlet builds and elbow that comes with provisions for the stock linkage. https://ls1tech.com/forums/nitrous-oxide/404043-nitrous-outlet-ls1-intake-system.html
http://www.nitrousoutlet.com/installs/install.asp?id=22
Ricky
Ricky
