Harlan 2 step plus TwinTurbo = big difference.
Old Apr 19, 2006 | 09:26 PM
onfire's Avatar
Coal Mining Director
Default Harlan 2 step plus TwinTurbo = big difference.
That Harlan fella is one smart dude. Don't know what's inside the magic black box, but it works.
Footbrake last season without it would bring the vac to zero....no boost at launch
2step set at 2200rpm = 5.2psi at launch
I'm surprised how smooth it works...I was expecting a stutter box kinda launch.
Life is good.
Old Apr 19, 2006 | 09:33 PM
frcefed98's Avatar
man I can't wait till he releases his new 2 step
Old Apr 19, 2006 | 09:47 PM
Navy David SS's Avatar
Just add a trans-brake. Hold button and launch at 4200 rpm. That's at least what I will be trying once the car is up and running.
I have one of Harlan's 1st ones made. Lost the top and not sure if it works still. Just sits there.
David
Old Apr 19, 2006 | 10:47 PM
DERTY's Avatar
The Bull
The new two step lets you foot brake the car with the two step armed to help build boost. Then add the transbrake and another two step point (same box) and build more boost faster than on the brake by itself. Should be twice as much fun when you guys get a chance to try it.
Old Apr 19, 2006 | 10:49 PM
onfire's Avatar
I unhooked my transbrake for the 2 step. You may need a 2 step to control the stall on the tb. My tb was too unstable to use...1 second = 3800rpm and 9psi....2 seconds = 4400 rpm and 13psi...you had to guess a launch and then it was way too violent and blew the tires off.....2 step is nice...you could use it to control the upper limit of the boost and stall on a tb.
Old Apr 19, 2006 | 11:11 PM
CAT3's Avatar
Restricted User
Why dont you run the transbrake with the 2Step? I'm not FI, but I am nitrous. I intend to install my H2S in-line with the transbrake, so one button does it all. I need to get my H2S off the shelf and into the car one of these days...damn it.
Old Apr 19, 2006 | 11:59 PM
Toonz's Avatar
I'm thinking that one of his new ones needs to go in my car while it's there.
Old Apr 20, 2006 | 02:43 AM
Moparnos (The SLP Guy)'s Avatar
Flossin' twin turbos
nice when is he releasing the new one?
Old Apr 20, 2006 | 07:46 AM
y2khawk's Avatar
Hopefully soon. I've got a couple bugs kicking my *** at the moment, and some travel for work coming up. But I'm plugging away on it.
Old May 31, 2006 | 11:31 PM
FormulaFire's Avatar
Just checking.. Any update on this. has the new 2 step been released? And how does Synergy's 2 step compare to harlan's? I noticed that Synergy just releases a two step. hmmm
Old Jun 1, 2006 | 12:01 AM
longrange4u's Avatar
I have never built boost on my 2-Step... Its a six speed and I do get out of vac... but no boost. Am I doing something wrong?
Old Jun 1, 2006 | 12:10 AM
LTLHOMER's Avatar
I always thought the way to get stick cars to build boost was the retard the timing...simply having a two-step probably won't help as much as it would on an automatic car.
Old Jun 1, 2006 | 12:47 AM
y2khawk's Avatar
Every bit helps
I could make a few psi on the 2 step with the 6 speed in the car. But the time from launch to full boost was night and day difference with and without.
On a stick car, pulling timing helps a ton. Not so much on a converter car. A BIG reason why I've added adjustable retard into the new 2 step itself. No reason to change anything in the PCM if you can twist a **** instead
I'm already making harnesses for the new one, and waiting for a quote back from the assembly house.
Can't comment on the the competition, as i've not seen one yet.
Old Jun 1, 2006 | 09:03 AM
i just hope you get it out soon brotha
Old Jun 1, 2006 | 01:04 PM
GrahamHill's Avatar
It does help on a stick car somewhat.
If your holding the RPMS manually then your probably at less than 20% throttle position with your foot when its time to start coming off the clutch and go.
With the 2-step your at the same RPM point at every launch and at 100% throttle position when its time to go.
Old Jun 1, 2006 | 03:28 PM
LTLHOMER's Avatar
I'm talking building boost wise...but it sounds like Harlan is going to have it capable of retarding timing as well which means it's going to be the best of both worlds for both stick and automatic cars.
Old Jun 1, 2006 | 03:34 PM
LSxChevelle's Avatar
Very nice to see a new one coming out as I sold my old one and now wish I didn't... I guess it was for a good reason to sell the old!
Old Jun 1, 2006 | 08:13 PM
MY99TAWS6's Avatar
Not sure why they wouldnt work good in manual cars. Have them in my dsms and they are manual and they work great.
Looking forward to harlans new one likely get it but was wondering why more companies dont' have it software like my dsm tuning software?Dsm software tuning programs also have something called anitlag in there..
