turbo guys in please
Old Apr 21, 2006 | 11:05 AM
Q8CamaRo's Avatar
Default turbo guys in please
i have few Quiestions about fuel system u r using,
1-what size of injectors that most common used
2-do u have idle issues?
3-what is the max boost u can get from Precision GT76
4-could the Stock PCM handle the #84 low impedence injectors?
thanks in advance
Old Apr 21, 2006 | 11:12 AM
Boostaholic's Avatar
42lb/hr is pretty common, I run 96
No idle issues at all, even with a big nasty cam and low comp
You would have to check your compressor map for that turbo to figure out stuff like that.
I think there is a Low-Z >> High-Z inpedence converter box you can buy, I also think you can buy 75LB/HR high-Z which would probably get the job done unless you have a pretty extreme project.
Old Apr 21, 2006 | 11:13 AM
MECHAM's Avatar
60# mototrons
no - get a tuner
i dont know...
no..high imp only
Old Apr 21, 2006 | 11:39 AM
Q8CamaRo's Avatar
thanks alot guys u make evrything clear
Old Apr 21, 2006 | 12:00 PM
DrTurbo's Avatar
LS1TECH Sponsor
thanks in advance
1- 60lbs
2- none if tuned correctly
3- depends on the engine size and flow, but ~18-20psi max with a GTS unit on a 346
4- no it can not, but you can buy the impedance convertor and splice it in. Then you can run whatever you want.
Old Apr 21, 2006 | 12:14 PM
Q8CamaRo's Avatar
where can i get that converter?
and how much?
thanks DrTurbo
Old Apr 21, 2006 | 02:57 PM
mdhmi's Avatar
I run 60 # Mototrons.
Not at all.
Depends how large your motor is, among other things. I know you can make enough to make 750+ rwhp on a 346.
No idea. Why do you need injectors that large?
Mark
Old Apr 21, 2006 | 03:25 PM
smokinHawk's Avatar
cause of the t76gts perhaps?
Old Apr 21, 2006 | 08:44 PM
DeltaT's Avatar
The 75# injectors are RC Engineering and are rated at 75@55psi fuel pressure. I got mine from raceprovenmotors.com, for about $680. Easy to tune - no problems at idle whatsoever. These are the largest hi-impedance injectors I've seen.
Jim
Old Apr 25, 2006 | 04:18 PM
nitrorocket's Avatar
I run a stock pcm, 96 lb injectors, injector driver. I am going to trade them for 72 or 83 lb eventally. I have slight eratic idle AFR. Not musch need for 96lb unless you have a 900+ rwhp car.
