My boost gauge doesnt show me getting positive manifold pressure...
Old 04-21-2006, 08:12 PM
smokinHawk's Avatar
did you ever get your cooling problems straightened out?
Old 04-21-2006, 11:42 PM
BLk01SS's Avatar
Ever consider that when you left the battery off, that the Eboost settings reset??
Old 04-22-2006, 11:34 AM
2000 Tran Zam's Avatar
well ive disconnected my battery before and this didnt happen, so I would think this wouldnt be the case.
Old 04-22-2006, 11:35 AM
A little bit.
I jacked the front end up and bleeded the cooling system a bit, there was quite a bit of air in there.
It still gets pretty warm, but not quite as easily though.
I still want to get a heat shroud put around the turbo to keep it insulated, I think that will be the cheapest way to start.
Old 04-22-2006, 05:30 PM
blackz93's Avatar
Is the car pulling, or no? Is it just a gauge problem?
Old 04-22-2006, 08:28 PM
it pulls, it just doesnt feel like it pulls as hard as it was before.
And Ive noticed that ive been getting excessive whiteish smoke on decel more frequently then before. I hope its nothing serious.
Old 05-01-2006, 09:14 PM
Scalpel's Avatar
White smoke = coolant (for the most part, it's not 100% but is usually indicative of such)
If you're lifting the heads that would be allowing air to get in the coolant passages and cause heating issues.
Does your coolant level in the radiator stay at the same level?
Old 05-02-2006, 02:19 PM
When Ive checked it lately it has been pretty steady.
what would cause me to lift the heads(if thats the case) other then too much boost?
im only running 12psi, so this shouldnt be the issue.
Old 05-02-2006, 02:21 PM
ddnspider's Avatar
Received 1,737 Likes on 1,298 Posts
ya i doubt you'd lift the heads just from 12 psi.What do you have for head bolts/studs?ARP studs i assume?
Old 05-02-2006, 02:34 PM
Ya, I believe so.
I mean the heads held when it was dynoed and ran at 16 lbs, so 12 lbs should be a walk in the park.
Old 05-03-2006, 01:35 PM
Scalpel's Avatar
Pressure test the cooling system to check for leaks, including pressure testing the radiator cap.
I'd do a leakdown too w/rad cap off to see if any air bubbles come up in the radiator, that'd indicate air getting into the coolant via the cylinder/head area.
Old 05-04-2006, 02:55 PM
  #32
Ya, Im gonna have allan do a diagnostics check on the vehicle when he gets it back.
Hopefully it wont need to be there too long, but as long as necessary to make the car working properly.
Quick Reply: My boost gauge doesnt show me getting positive manifold pressure...
