Supercharging advice, anyone????????
Old Apr 22, 2006 | 08:55 PM
j88l98irocz's Avatar
Default Supercharging advice, anyone????????
Hi guys, I have a 2000 camaro ss m6 and I changed my mind about nitrous, I want to go with the supercharger instead, the car allready has the patroit stage 2 ls6 heads, cam, intake, slp longtubes,ported tb,pullys and the coolant bypass. stock bottom end and stock 3.42's the car dynoed 422 hp to the rear wheels. how much boost can I safely run b4 I hurt something ? what is a good supercharger kit ? advice would be greatly appreciated thanks John.
Old Apr 22, 2006 | 09:32 PM
Urban Legend's Avatar
TECH Cry Baby BOSS APPROVED!
10 pounds of boost courtesy of a Procharger D1SC will net way over 500 rwhp very easily.
Old Apr 22, 2006 | 11:29 PM
LSs1Power's Avatar
Depending on your Compression Ratio.... Since your setup made 422rwhp i would think you have over 10.5 C/R maybe close to 10.8 C/R. With that much C/R you should be over 500rwhp with only 6psi easy. Good luck.
Old Apr 23, 2006 | 12:09 AM
DeltaT's Avatar
What CR, injectors and cam specs?
Are you willing to run a large intercooler in front?
Who's going to tune this, and what tool?
Jim
Old Apr 23, 2006 | 12:59 AM
JMBLOWNWS6's Avatar
My best advice is have plenty of $ on hand.
Old Apr 23, 2006 | 06:32 AM
Black LS1 T/A's Avatar
Moderator
Hi, UL ...
Please remove the advertising links from your siggy until you become a sponor of the site. (Forum policy.)
Thanks, man ...
Old Apr 23, 2006 | 09:02 AM
Got Me SOM's Avatar
word to the hizzo.
Old Apr 23, 2006 | 09:12 AM
unit213's Avatar
Administrator
As LSs1Power mentioned above, CR will be key so you need to let us
know what your current compression ratio is. I too would suggest
a D1SC from Procharger.
You didn't mention what fuel mods you've done, but keep in mind
that your fuel system will most likely need some work done as well.
If you really want to be safe, run 6psi through a D1. You'll see some
nice power and the motor will be very reliable.
Originally Posted by Black LS1 T/A
Hi, UL ...
Done per your request.
Old Apr 25, 2006 | 09:20 PM
thanks guys, the fuel system is stock except for 24 lb injectors and im not sure of the compression they are the patroit stage 2 ls6 heads with a stock short block
Old Apr 26, 2006 | 05:01 AM
EPP's Avatar
EPP
With an ATI ProCharger D-1SC, I'd shoot for 7 pounds of boost with your head/cam combination. You will easily make over 500 rwhp and with a good tune you will have a very nice combination. Bob
Old May 3, 2006 | 02:49 PM
Moderator
Thanks for being a team player...
