copper exhaust gaskets
i was thinking about running copper or alum exhaust gaskets and reusing them instead of buying new gaskets every time i take apart the exhaust, what do you guys run and is there any reason anyone would reccomend one type over the other?
dont need gaskets with 1/2" thick flanges? does that apply to turbo cars as well (specifically STS since most of the exhaust is in front of the turbo)?
also, i have a friend who tells me our exhaust flanges are different from the "standard". i guess this means we cant just buy a gasket off the shelf huh?
1 vote for copper, and 1 for stock. anyone else have an opinion/preference?
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
I blew several sets of paper and graphite/wire gaskets at less than 100 miles. I then switched to aluminum and they went less than 10 miles. Now I use copper and they work great. I think shim steel would work also.
Mike
Mike
I like the Earl's Pressure Master Exhaust Gaskets. The inserts are pressed Graphite, like pencil lead, but you can trim them and they are replaceable and they last for a long time (>1 season). Available in different port shapes, sizes. Summit Racing.com
If you take it apart, you can just put in new inserts, for like $11.
Jim
Jim
