Help selecting the best turbo cam!
We did a 226/220 on a 115 and the cam was very near stock idle.
I see a few schools of thought regarding turbo cams:
1. Standard split- Large exhaust duration compared to intake, which allows more exhaust gas to spin the turbine. Let the boost do the work on the intake side, and couple it with a wide LSA to minimize reversion. This is your z06 and GT2-3 cams.
2. Reverse split- Run a larger duration intake to allow more air and fuel in, and run a smaller exhaust duration to minimize overlap and thus reversion. This allows a tighter LSA to be run. An example would be the 226/220-115 cam above.
3. A comp tech rep said that they size it like a N/A cam, then they reduce the duration 10* and biased the exhaust about 4*. The reason they don't like reverse splits, because they feel its the old school way, since turbines are far more efficient now.
4. Single pattern- I'm not sure as the reasoning behind this, so maybe some one fill me in.
I'm sooo confused!!!
Too much exhaust duration can increase backpressure (for a single turbo setup) to the point where you have to dial down the tune.
Duration (intake/exaust) 221/214
Lift (intake/exaust) 540/532 (1.5 will be using 1.6)
Lobe Center Separation 115
Intake Centerline 112
The cam was custom chose for towing and play power.
