KB 2.4L blower on a 402
Old Apr 28, 2006 | 06:24 PM
pakisho's Avatar
Destroying belts? Whoops! I havent heard that! He's having belt issues? Thought the car would be in vegas by now....
Old Apr 28, 2006 | 06:42 PM
mdhmi's Avatar
All that info is in his master thread on CF. They've already been through a dozen belts. I'm not sure if they are chucking them, tearing them, or what. I'm really not surprised as this is a totally new combo. Some brackets or balancer (don't recall) from ECS, some parts from KB, etc. Any new combo like that will take time to get dialed in just right.
For now the car is still at Synergy while they try to figure out what to do next.
I'm not saying anything against Jeff's buildup or KB, but when I see how long some people go without their cars while testing new products I'm just happy that I went with a proven turbo package. Granted my setup isn't unique and I'm not setting any hp records (low boost), but I get to drive my car every day and enjoy it.
Mark
Old Apr 28, 2006 | 07:46 PM
Wet 1's Avatar
It sounds like he's doing KB's R&D work, on his dime. I wouldn't be happy with the lack-luster results or the problems. I don't think this blower will ever break 750 rwhp, and certainly not on pump gas.
The tq is impressive, but it's hp that posts the big number at the end of the 1/4, not tq.
Old Apr 28, 2006 | 07:54 PM
Nine Ball's Avatar
LS1Tech Co-Founder
I disagree, he isn't doing KB's R&D work. They sell the kit with the largest pulley on it, and a specific HP rating. Once you cross that line and want to make more power, its your own R&D time and dime.
Its actually the highest average HP thru the racing RPM powerband that is important, not peak HP numbers.
Old Apr 28, 2006 | 08:09 PM
Wet 1's Avatar
So you're saying the blower is only designed to be run with that big pulley making 6psi????????????????????????? Come on 9, you know as well as KB does that it's a power adder and 9 people out of 10 are going to want to make more than 6psi with the thing. Also, read the thread, KB wants him to push it farther so they can see what it will do... they want him to find flaws and find the limits of the blower. I call that R&D.
And since the RPM range during a race is typically over 4800 rpm throughout the run, low end power/tq isn't nearly as important as top end hp.
Old Apr 28, 2006 | 08:42 PM
LSs1Power's Avatar
I can see this setup working great on a Yukon. It would move the Yukon as if it was a 3000lbs car with all that TQ down low. If i want a drag car i would still stick with a Centri or Turbo setup, but its still nice to see more options out there.
Did they ever mention the IAT on the KB at 14psi? That is a major concern of mine with any Roots or Whipple blower.
Old Apr 28, 2006 | 09:31 PM
SSilverSSurfer's Avatar
thats gonna be bad *** when they get the finished product
Old Apr 28, 2006 | 09:46 PM
FAST LS1's Avatar
It's great how people with car's that don't even break 600rwhp are saying this first kit by KB isn't anything special.
This is the first consumer car with this supercharger kit, and not only that he's pushing it to the upper limits. Let the guy work out the pulley issues, as he explains in his reply on the CF. He's also having other issues as it's a totally new engine with a totally new FI kit.
The sad fact is he probably will reach ~750rwhp on 91 octane/meth and it is a big deal, and everyone's playing it down. His trq curve isn't a curve at all, it's a straight line, and his power curve is completely linear. That will make for a car that's very easily to modulate the throttle when racing. There's no hitting boost, or spooling, it's just linear hp and flat trq.
All the nay sayers can come back crush this guy when they make a car with a new FI kit that rolls out with 1000+rwhp on the initial dyno tuning runs.
Old Apr 29, 2006 | 02:07 AM
NA$TY-TA's Avatar
cool.... ill keep watching...
Old Apr 29, 2006 | 09:56 PM
BUYAMERICAN's Avatar
Yep. The owner will tell you it just COMPLETELY just blows away his previous former F1-C setup on acceleration and thats its not even close.
As an outside observer. I happen to agree with WET on the R&D and everyone will benefit in the end.
The brackets are being made super beefy for high boost applications.
They were bending ever so slightly under load.
Enough just to barely get the belt.
They were previously beta tested to 9 PSI..
Nineball
"Its actually the highest average HP thru the racing RPM powerband that is important, not peak HP numbers."
Alsolutely correct. This thang is very fast, like a 402 on a big shot of totally computer controlled spray, not from 3,200, but from right off idle.
Old Apr 30, 2006 | 09:52 AM
97F1R408's Avatar
Honestly, if this car makes the same power from 2300-6000 or actually falling off with rpm why would you drag out the shifts any higher than lets say 3000rpm ? wouldnt you be wasting time in every gear not really accelerating? I spend alot of time calibrating valve bodys on diesels after mods and getting shift timing while making power not after it stays constant. and thats what this thing sounds like its going to need (could be wrong). One thing I see is that this blower that does so well on stangs isnt much smaller than the one on this car but those mustangs dont even have 300ci , The turbo on my 370 truck works perfect but if I put it on my 408 I think it would be a little under rated and thats 38ci I could only imagine 100+ . But I could be on crack though. Sounds like the first vet with a duramax to me.
Old Apr 30, 2006 | 10:06 AM
  #32
Stang's Bane's Avatar
His h.p. curve is not flat, his torque curve is. His horsepower curve is going up at an even rate not at an ever increasing an curve. It looks more like a straight line and not actually a curve. The car is still constantly accelerating at an increasing rate, but not one that is unmanageable.
Old Apr 30, 2006 | 10:12 AM
  #33
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
He running 8 rib, 12 rib or cogs?
Old Apr 30, 2006 | 11:18 AM
  #34
mdhmi's Avatar
He is running an 8 rib from ECS. A 12 rib or cogs setup won't fit a C5.
Mark
Old Apr 30, 2006 | 06:09 PM
  #35
The brackets came from three sources.
There are new BIG billets ones that were just cut.
5,000 rpms of flat line torque band is a racers wet dream.
Old May 1, 2006 | 01:18 AM
  #36
chuntington101's Avatar
will the uprated brackets be avaliable with the SC or are they an after thing??
Chris.
