is there such thing as lower compression headgasket on a LS1?
Old Apr 27, 2006 | 03:19 AM
2002/Black/SS's Avatar
Default is there such thing as lower compression headgasket on a LS1?
i know imports have them for sale that lower their compression like a half point at the most, but can u get a thick headgasket for an LS1? does it excist?
Old Apr 27, 2006 | 05:14 AM
smokinHawk's Avatar
yes cometic sells them from thicknesses to .054-.125"
Old Apr 27, 2006 | 12:30 PM
so it would be worth it for me to buy one after i get my turbo kit in 2 weeks??
Old Apr 27, 2006 | 12:37 PM
fletchls1's Avatar
I have been told they have some problems..now that i think of it, my friend had one installed and had problems with it also..
Old Apr 27, 2006 | 01:08 PM
ChaseSS's Avatar
i guess you could put them on but thats a lot of work to take off the heads and change the gaskets just for a little bit less compression... unless you are changing the heads already??
Old Apr 27, 2006 | 01:12 PM
if i change the gasket it would mean im puttin on patriot stage 2 6.0L heads
Old Apr 27, 2006 | 01:24 PM
SUPER DAVES Z's Avatar
If you want to use the cometic gaskets to lower compression, I wouldn't go bigger than .073 (or whatever size it is). After that, you're really hurting quench. I've never had a problem with my cometic gaskets, even after reusing them 3 times.
