Holley/Lingenfelter Manifold good for boost?
Old 05-09-2006 | 02:52 PM
fenix99's Avatar
Restricted User
Default Holley/Lingenfelter Manifold good for boost?
like the title says i can get one cheap brand new and wondering if the Holley/Lingenfelter Manifold is any good for boost...i was planning on port matching the heads with the manifold as well as porting everything else i can get my hands on, so...
anybody have experience with this manifold on boost...b/c i know ive seen a few guys around my area with that weiand manifold but for SPRAY...
lemme know guys, thnx in advance
Old 05-09-2006 | 03:33 PM
~JOSHUA's Avatar
It's a 35 pound chunk of aluminum. It would take serious pressure to hurt that thing.
Old 05-10-2006 | 12:24 AM
fenix99's Avatar
Restricted User
yea i know the weight is an abvious drawback if u wanna call it that...but WILL IT MAKE MORE POWER when i port it? >that is the question that im concerned with most
Old 05-10-2006 | 02:33 AM
fenix99's Avatar
Restricted User
ANYONE use this manifold on boooSTTTT??? cmon i know somebody has to have at least tried it on a turbo setup??...??...???...???...???
Old 05-10-2006 | 02:45 AM
ChaseSS's Avatar
it will definately make you more power with boost, I wouldn't consider the weight a drawback (very small difference) but the heat sink. The aluminum won't desperse heat like a composite will
Old 05-10-2006 | 05:57 AM
EPP's Avatar
EPP
This intake is basically a duplicate of the LS6 intake, although some test have resulted in performance being somewhere between the LS1 and the LS6 intake. The Weiand intake uses paper gaskets, which do not seem to seal as well as the factory O Ring seals.
If I was going to spend the money on an aluminum intake, I would use the Edelbrock Victor Jr that is designed for our LS engines. It is going to give each cylinder an equal amount of airflow, better than a stock based intake can. Bob
Old 05-11-2006 | 03:37 PM
ESR's Avatar
ESR
LS1TECH Sponsor
Default weiand
I have one on my car. Ive taken it off three times never had an issue with sealing properly. I am going to the Vic jr. though. It seemed to do well for me. right under 700 on a mustang dyno w/ 17PSI and meth. I never had an ls6 or anything else on it so I have nothing to compare it to. It is port matched though.
