Any Guesses On Power And Tq?
any thoughts on how she will do? SPECS:w2w short block 9.27:1 comp., stage one prc 6l heads, gt7 cam and all of the supporting valve train. take some guesses
new engine...with lower compression
different cam
again 10psi dyno
then 12psi dyno
10psi should probably be close to the same. this is definitely a good test of cams.
12psi 635/660
