MS3 and boost?
Old May 12, 2006 | 10:42 AM
udlose99ta's Avatar
Default MS3 and boost?
Just wondering if anyone could tell me how the magic stick cam will perform under boost? its the 113lsa, i already have this cam and love it N/A but want the most out of my future turbo setup (sts 10psi) thanks...
Old May 12, 2006 | 11:02 AM
markp03's Avatar
try it then mesure boost versus back pressure then talk to a cam builder
Old May 12, 2006 | 12:03 PM
udlose99ta's Avatar
i was told it was a great nitrous cam, so i would think it would like boost as well??? Dunno.
Old May 12, 2006 | 12:11 PM
markp03's Avatar
negative they are different...with a turbo cam you want the right abount of overlap so that you dont bleed off too much boost but at the same time spool the turbo fast. I personaly don't know much about it but you can check out some info about turbo cams at
http://www.forcedinductions.com/help.htm
down near the bottom there is info on turbo cams
Old May 12, 2006 | 12:27 PM
Q8CamaRo's Avatar
not to hijack your thread but how to musure the backpressure?
Old May 12, 2006 | 12:37 PM
udlose99ta's Avatar
i would like to know as well...
Old May 13, 2006 | 01:13 AM
markp03's Avatar
you have to tap your exhaust and use a pressure gauge...i belive snap on sells a kit to do it...I am sure you could find one online somewere
Old May 13, 2006 | 09:48 AM
SilverSS's Avatar
I have the MS3 with the STS on a T67. Not the choice cam for FI but there are no problems here.
