Is a 224/228 cam, 114 lsa, with .575 lift, good to go with 918 springs on D1SC
On a D1SC set-up making around 700rwhp on 14 lbs of boost? I know these springs are good to go at least up to .600 lift (Brand new 918s), but does this boost level make it a necessity to run a double spring, or should I be good to go!!
My buddy that works at comp tells me they just came out with some new beehive springs that can handle .650 and .750 lift. May want to check into that. I have a Lt1 car using a 224/230 cam with a .605 and .622 lift and I plan on using a new Single Beehive part number 26986 Beehive version of the dual 986 spring, maximum lift .650 and a 1.412 O.D.
