Alky pump is on all the time ?????
Old May 17, 2006 | 06:17 AM
Schurters LT1's Avatar
Default Alky pump is on all the time ?????
I have been working on the car for a few months now ...hooked up power to night and turned Key on and the pump is on all the time ? the switch is doing nothing....
this is ALKyC kit (julio)
when i put the white pump wire to power (with out ground) it comes on ?
the switch will do nothing ? (on/off) when i have power and ground hooked up
as fare tell everything id hook up right, but i am sure i am missing something here...
at the pump i have the ground wire to the frame the white wire is at 12v key on, then the ground to body...
i have the red and black wire hooked up to the same 12v key on power..
if you have any ideas...
Old May 17, 2006 | 06:55 AM
Blown SS's Avatar
If it is the progressive kit the motor does not get grounded , both wires go to the controller . Give Julio a call , I'm sure he will take care of you .
Old May 17, 2006 | 06:57 AM
KraZy's Avatar
Julio is at the Buick Grand National event till the 22nd.
Old May 17, 2006 | 07:06 AM
BOOSTNSS's Avatar
ok do you have the map setup to a 5 volt source? that sounds like the prob.
