D1-sc pulley shims?
Old May 17, 2006 | 07:21 AM
Junior's Avatar
Default D1-sc pulley shims?
I just changed the pulley on my D1-sc for the first time and when i took the pulley off there was this pretty big and kinda thick washer there. Is that supposed to stay on or is this a shim ? The reason im asking is because in my SDCE instructions it says to remove all old shims and just run the shims they provided. Any help would be appreciated, thanks
Old May 17, 2006 | 10:26 AM
Fire67's Avatar
hmm, not exactly sure. One way to tell for sure though would be to install without ALL old washers/shims and with only the new ones. Then check pulley alignment with a straight edge.
Old May 17, 2006 | 11:49 AM
Junior's Avatar
Thanks, i'll try that
