Dyno results for twin T70 GTO
LS1TECH Sponsor
Originally Posted by braap
Downpipes are 3"...it was a little tricky getting everything to fit well, and it's tight in some places. Air filters are in the pockets just in front of the wheel wells...had to loose the washer reservoir and cut a bit of sheetmetal out of the way to make it happen.
What turbine housing are you planning to use with that set-up?
