751 RWHP on 93 Octane
I run a Niel Chance bolt together 10" converter. Holds super tight.
After the dyno pull, I logged a pass on the street ans still only got 14 psi. I turned it back up and the car is back to normal power wise.
I run 8.1:1 compression.
I will hopefully be running at the track in the next month or so. My guess is high 9's at about 145-150 ish. Hopefully the new converter holds this time!
I log the AFR at 11.3, tha dyno logged it at over 12:1!! Not sure whats up with that.
![](http://i8.photobucket.com/albums/a50/nitrorocket/DVC01105.jpg)
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
![](http://i8.photobucket.com/albums/a50/nitrorocket/20065-200291.jpg)
I launch the car off the trans brake. I am in the process of setting boost limits per gear. This will help my launch alot. 1st gear will not hold 16 psi real well! It will 60' a 1.60 on the 17's.
TT402LS1. I will be at a show this weekend on Saturday. I will P.M. you later.
So help me out. . . I'm pulling lazy 1.85 60' times because of turbo lag. Because of this, I'm stuck in the mid 10's at 143 mph. My old T-trim supercharged setup ran the exact same et, but at 10 less mph. I know I need a trans-brake, but my car is a true street car so I don't want a full-manual valve body. Does anyone know of a trans-brake that allows you to keep full-auto operation?
Mike
Mike
I am not sure if there is such a trans brake. When does your boost come on? can you foot brake a little?
The only pass I have with my turbo was in fall. I broke at half track. The converter started flashing to 7000 rpm and stayed there, I got out of it a few times but it kept doing it. Would not accelerate under WOT anymore. My new converter fixed this problem! It still went 10.50@137 with a 1.83 60'.(Took off to light, thought I would blow the tires off).
I tried foot braking, but again, I can only get a little over 2000 and no boost without pushing through the brakes.
Mike
#32
Originally Posted by engineermike
The boost comes on around 3000. I have a 2-step set at 2100 rpm. Any higher and it pushes through the brakes. At 2100 it's only building about 2 psi boost.
Mike
Mike
Andrew
#34
My opinion is that you need a higher stall to get into the torque curve. You should be able to foot brake to 3000 or so to get boost up. You have a very low stall!
Sorry for the hijack, BTW.
Mike
#35
I agree, but once my turbo spools up, it flashes to 5500 rpm. 22% slip on the big end!!!
Mike
Mike
#37
#38
Originally Posted by Wicked_Hugger99
Just curious, Is it safe to run 14-16psi on pump gas or do u have an alky or meth injection??
LS1 guys seem to be the only ones who will recommend 9.5:1 compression motors in forced induction applications, then be scared to run any boost at all.
#40
Not all LS1 guys are advocates of near-stock compression. I'm an advocate of 8-8.5:1 compression for a pump gas FI car trying to hit over 700rwhp.
