cam good for a supercharger
Old May 25, 2006 | 03:20 AM
TXZ28LS1's Avatar
Default cam good for a supercharger
will a 228/232 588/575 113 work with a procharger running bout 6-8 lbs of boost!! i wanted to do a stall and cam setup first then get the blower.
Old May 25, 2006 | 04:47 AM
EPP's Avatar
EPP
That cam is not really suited for being a blower camshaft. The Lingenfelter GT2-3 cam would be a better choice. Bob
Old May 25, 2006 | 09:39 AM
TXZ28LS1's Avatar
i saw a guy run a cam along those kinda specs making over 500rwhp!!! and i cant find that one post about a guy who used a big cam with a blower..i think the title was who says you cant make power with a big cam or something.. how bout 224/224 cams for blowers?
Old May 25, 2006 | 10:20 AM
Spade's Avatar
I had my D1SC installed by EPP. I already had a 224/224 114 cam in the car at the time. I put down 460/440 on there Mustang dyno. That is through an auto. Not the best FI cam but it works. It all boils down to what you want overall. I just replaced mine with a GT2-3 but I am still in the process putting the car back together.
Old May 25, 2006 | 10:30 AM
~JOSHUA's Avatar
I've got a Lunati 236/236 112+2 that would be crappy in a Procharged motor, but it sounds so brutal right now N/A, I can only imagine it with that D1 blower whine.
I know I'll have to change the cam later this year, but I wish I could just run it as-is.
Old May 25, 2006 | 04:17 PM
TXZ28LS1's Avatar
what i want to do is run a stall and cam first. then save up for a s/c. i want something thats gonna be fun on the street. i just hope my tranny and rear holds up when i do a blower. i dont dog my car anyways.. so it should be fine.
Old May 25, 2006 | 05:21 PM
Black LS1 T/A's Avatar
Moderator
My tranny (4L60E) was good to almost 500 RWHP. But, you never know.
Of course, the 422 killed it the first couple runs.
Old May 25, 2006 | 05:35 PM
618HAWK's Avatar
Keep us updated on how it works out for you. I am still waiting to install the same.
Old May 25, 2006 | 06:45 PM
DeltaT's Avatar
I think that cam work work fine with a blower, especially a centirfugal. I'm running a solid roller 230/236, 112lsa on my Vortech-blown 383, and it is running great. I max out the blower at 7.5#, but that's because it's not a big enough blower. Your cam doesn't have a lot of overlap and should be a good combo of on and off boost.
Jim
Old May 26, 2006 | 02:51 AM
TXZ28LS1's Avatar
thanks guys. i know you cant go wrong with a 224/224 cam. hey if should i go 3200 or 3600 stall? and what gears 3.42 or 3.73.. eventually to match a procharger running 6-8lbs..
Old May 26, 2006 | 06:03 AM
EPP's Avatar
EPP
Check out the Comp custom grind that we use and sell in the store area of my website. This camshaft is a thumper and we have found this camshaft to work exceptionally well with the ATI ProChargers, and it is the camshaft I will be installing in my own Z28. Bob
Old May 27, 2006 | 01:24 AM
Kraest's Avatar
I have a little baby cam in my car that you can't hear lope and gets 21/27 mpg, but puts out some serious power
Mike
Old May 27, 2006 | 01:59 AM
TXZ28LS1's Avatar
ill probably be going with a 224/230 cam. im gonna do a cam and stall first before the blower.
Old May 28, 2006 | 10:45 AM
Spade's Avatar
I would get the bigger stall. Only because you will want more down the road. Trust me, been there. Just be sure to get a FI friendly stall.
Old May 28, 2006 | 06:23 PM
engineermike's Avatar
228/232-113 isn't very far from 224/230-114. I bet the difference is less than 5 hp on the dyno and the 224 cam may be the loser. The 224 cam has 5 deg less overlap, the intake valve closes 1 deg earlier, and the exhaust valve opens at the same time. The 228 cam only has 4 deg of overlap which really isn't that bad.
Old May 29, 2006 | 04:47 AM
TXZ28LS1's Avatar
so which cam would you guys suggest? which brand stall is FI friendly? i wonder what the performance would be just blower only vs. blower, mild cam, and stall? remember im not trying to rip 10's seconds and all..lol. hey anybody know a ballpark estimate hp i would be making on an auto with all bolt ons minus the stall and cam? pushing bout 7 psi?
Old May 29, 2006 | 08:23 AM
Pick any cam you like that has less than 5 deg overlap and at least the same exhaust duration as intake. Choose an intake duration that gets you the rpm range you want and keep in mind that a centrifugal supercharger adds about 500 rpm to the peak hp and torque.
As for stalls, with 700 fwhp, the converter will stall roughly 1000 rpm higher than rated. The Vigilante converters I know are tough, but get pretty loose when you really start putting power to them.
Mike
Old May 29, 2006 | 11:45 AM
Spade's Avatar
I know Yank makes convertors specifically for FI. I dont know about others.
