A realistic HP guess?
Old May 26, 2006 | 09:56 PM
80superbu's Avatar
Default A realistic HP guess?
Just thinking again What would be a rough guess of my potential HP with this setup:
LS1 @ 3.905
Scat H beam road w/ARP bolts
6.0 heads ported/polished w/2.08 & 1.6 valves
Cam is 228/224 603/600 on a 115+4
Diamond pistons..final compression 8.7:1
FAST 90 intake NW 90 TB
FAST fuel rails
Injectors I have now are 50's but I may be upgrading SOON!
GT42 turbo
FMIC core size 24x12x4..1000hp capable
fuel system will support 1000hp
Thoughts??
thanks
Old May 26, 2006 | 09:59 PM
80superbu's Avatar
No idea how much boost I plan to run just yet as everything is still in boxes. Most likely as much as I can get away with. Possible meth in the future
Old May 26, 2006 | 10:15 PM
OUTLAWZ RACING's Avatar
10-15 psi I guess 600-700+ rwhp
Old May 26, 2006 | 10:19 PM
cws T/A's Avatar
600s street 13-16psi 800+ race 20+psi
thats a good setup, what torque converter
Old May 26, 2006 | 10:26 PM
80superbu's Avatar
I haven't bought the converter yet. Trans is a full on race TH400.
My goal HP was 650 to the wheels. I think I will be pushing the 50lb'ers to reach that goal
Old May 26, 2006 | 10:28 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I'd get the 60lb'ers.
Looks like a very easy goal for you.
Old May 26, 2006 | 10:36 PM
quicksilverado's Avatar
With a good tune Bryan, you should make 600-650 easy. Meth and 60lb inj you should be in the 750-800 range.
Old May 26, 2006 | 10:42 PM
80superbu's Avatar
I've been thinking about getting rid of these 50's I bought ever since I got them. I figured they would end up being too small for what I wanted
Anyone wanna trade some like new 50's for something bigger
As for the tune, I still need to get a wiring harness for my conversion. I have a stock harness and computer from an 01 Z28 but the harness needs fixed to match my setup. Have been thinking about BS3 but $2k isn't easy to come by right now not to mention the $4k I need to finish getting everything else
Maybe I should change my cars name to "Project Money pit"
