should i run this
Old May 30, 2006 | 09:28 PM
c5_ls1_6spd's Avatar
Default should i run this
I've already have a cam (226/226 .585 112lsa) only set up with full boltons on my MN6 C5. i don't want to swap back in my stock ls1 cam, so can i run this cam with a procharger at about 5psi?
Old May 31, 2006 | 01:26 PM
any opinions guys?
Old May 31, 2006 | 01:30 PM
Frost's Avatar
It may not be the best, but it'll still do just fine.
Old May 31, 2006 | 01:57 PM
FUroundeye's Avatar
What Frost said.
Old Jun 1, 2006 | 04:25 AM
EPP's Avatar
EPP
Yes you can run that camshaft. It may not be optimal for a blower, but it will work just fine. The blower pulley will need to be a little smaller than what the ProCharger would normally come with, which can be ordered that way when you place your ProCharger order. Bob
