my FI PCV/Crank VAC system.
And the (none vented closed loop) PCV can goes inline between the valley cover and the intake , or the valve cover pcv line and the intake , with the GN anit crankcase boost check valve in between the out on the catch can and the intake , so under boost the check valve will close and prevent boost from presurizing the crank case, system fixed all my PCV issues in both my LS cars
-Coleman
each valve cover has a -10 to a vented breather tank.
but when not in boost i want to pull vacume. so hook the ls6 valley cover to a check valve and from that to the throttle body or manifold. right?
just visualize the path that air travels
when normal driving
air into breather vent, into engine at valvecovers, out of engine at ls6 cover, through checkvalve into intake
in boost
nothing goes from intake into engine because of check valve
engine can breath out of vented catch can if necessary
mine just also has a line to the inlet of the turbo so that during hair airflow (such as boost) that line will have a slight vacuum draw on it as well. this needs to go direct to the crankcase or it will just 'leak' at the vent
and
take a line out of the valley cover, through a check valve and into the intake behind the turbo
this line that runs to the vaccum side of the turbo, where is its other end?
the hose on the vacuum side of the turbo runs to the crankcase... filtered by the main air filter.
i tap this into the crankcase
ill try to type my stuff as simple as i can
i have (currently)
line1 from crankcase to air filter (happends to be ls6 valley cover).
line2 from crankcase to coalescing filter to 1 way check valve to intake.
large DIY breather valve mounted at oil fill cap.
line 1 draws on crankcase under boost (check valve on line 2 shuts)
line 2 draws on crankcase under vacuum (while line1 acts as the fresh air source)
breather valve sucks shut under vacuum and blows open if there is ever any positive crankcase pressure
Do you need it normally closed for extra crankcase vac to help scavenge return oil?
[IMG]
[/IMG] Do you need it normally closed for extra crankcase vac to help scavenge return oil?
i had the valve you are showing off about 9 years ago, its in the 5th picture in my first post in this thread.
