my FI PCV/Crank VAC system.
Old Apr 25, 2010 | 10:12 PM
  #121
bad6as's Avatar
sorry mm but im getting closer to starting my car and i want the pcv to be set up right.
the valve covers have a -10 an line going to the vented breather tank.
if i get blow by it vents out the tank?
but normaly it sucks in air threw the tank?
then off the ls6 valley cover i need a check valve to a catch can to to port on the ls6 intake manifold.
you want vacume on the rings when not in boost right? if i set it up like i just posted will that be correct?
Old Apr 26, 2010 | 04:09 PM
  #122
MIGHTYMOUSE's Avatar
sounds like you can just cap off the valley cover.
it depends on if you mind oil vapors or not.
i am sacrificing ingesting a little oil thru my intake to keep my turbo draining fine, the vac on the rest of the stuff around the crankcase such as rings is just a perk.
Old Jul 7, 2010 | 11:51 AM
  #123
vmapper's Avatar
Originally Posted by SilverCC
I have done alot of research on this sytem due to FI and pressurized crankcases I had a vehicle that I turbocharged and this is what I came up with this is a pic out of APS turbo instructions so they have this valve on the valley cover to intake and the valve covers going to turbo inlet I am pretty sure you can get this at any APS dealer!
[IMG] [/IMG]
Where did you purchase this check valve?
having a real hard time finding where you got something like that.
Old Jul 7, 2010 | 12:38 PM
  #124
YSILT1's Avatar
Vortech sells one very similar. I have seen it on there new 2010 Camaro SS kits.
Here is the part # 7P375-378
