PCV Options HELP!!!!!!!
Old Jun 16, 2006 | 04:28 PM
Fire67's Avatar
Just thought of this though, at cruise and in-gear decel the vacuum does get pretty high...
I have not yet set my evac system up... I was going to go with the header style evac system originally, then hooked up a vacuum/boost gauge to the crankcase (PCV port) and found that even with the supplied check valves I was getting positive pressure in there. At 3000+ rpm, it would drop to vac. just slightly though. So untill I set something up, Ive just got a pair of breathers on each cover
Old Jun 17, 2006 | 11:33 PM
MIGHTYMOUSE's Avatar
at 11 my crank seas were squealing as air sucked past them.. thats what i was told by 427.
