F1/F2 Procharger system...
Old Jun 8, 2006 | 10:42 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
A local friend made my 8 rib YSi Vortech setup.
You should plan to run a strut brace. 20-30 psi is no joke.
Old Jun 8, 2006 | 10:58 PM
Dune-LS1's Avatar
Cool... You got any pics????
Old Jun 8, 2006 | 11:48 PM
WNA B LS1's Avatar
Why the problem with Cogs on an LS1? Never heard of any problems on a standard sbc...atleast I haven't had any problems with my F2
Old Jun 9, 2006 | 09:35 AM
LS1Tech Co-Founder
A pic:
http://psj.ls1tech.com/gallery/main....&g2_itemId=152
Old Jun 9, 2006 | 10:01 AM
1fastWS6's Avatar
Who's bt carb are you running? What kind of boost?
Craig
Old Jun 9, 2006 | 10:39 AM
Got Me SOM's Avatar
Wont the YSi fit on the RMCR bracket they make?
Old Jun 9, 2006 | 10:45 AM
LS1Tech Co-Founder
Sure. But I'd stil run a brace for 30 psi.
Old Jun 9, 2006 | 11:23 AM
Got Me SOM's Avatar
John do you have a pic of that brace alone, I'm not sure what you are talking about when you say brace, i'm imagine its connecting to the blower but what's it boltin up to , the block somehow?
Old Jun 9, 2006 | 11:53 AM
LS1Tech Co-Founder
Brace bolts to crank and blower pulleys, using pilot bushings (?).
Old Jun 11, 2006 | 10:48 PM
HUGGER ORANGE SS's Avatar
PSJ...
DO you have any more info about running a YSI on a Vortech LS1 Setup. Can a YSI fit under the hood properly. My friend has the RMCR bracket and was planning on installing a T-Trim, but he's also got a YSI sitting there and wondered if it would fit under the hood of a Camaro SS..
Thanks.
CLint
Old Jun 11, 2006 | 10:52 PM
Got Me SOM's Avatar
hugger orange, my friend dave has the rmcr bracket and he runs the t trim. the ysi will fit on the bracket too. You will have to clearance the hood for it.
i might buy his t trim or jump up to the ysi in like a year with a front mount, should be fun!
Old Jun 11, 2006 | 10:53 PM
  #32
MECHAM's Avatar
Originally Posted by HUGGER ORANGE SS
PSJ...
Thanks.
CLint
yes..the YSI will fit under the hood of an LS1 (not sure about the SS). The bracket will support the YSI. If it is version #1 of the bracket a little bit needs to be cut from the bracket to work..but if its version #2 then no modification is needed. A T-Trim will fit the bracket no problem as that is what is was originally was designed for... Your friend might be able to send the bracket back to RMCR to have them cut for the YSI or he can pay an upgrade cost to version#2. Not sure of the upgrade cost...but I know he has version #2 brackets in shop
version #2 bracket is a lot nicer...still beefy but weights a lot less.
Old Jun 12, 2006 | 04:58 AM
  #33
ZO6MADMAN's Avatar
If TQ and boost are what your wanting the Kenne Bell or the WHipple will support your needs, roots blowers develope more TQ than the centrificual and i have seen a COG set up on a 4.6 Terminator....and last they will go 20psi i would think this would be the best application for you. The square peg shoving into a round hole sounds too tuff.
Old Jun 12, 2006 | 11:37 AM
  #34
LS1Tech Co-Founder
I think the YSi is bigger, but you could check with Vortech and see.
Old Jun 12, 2006 | 04:35 PM
  #35
Got Me SOM's Avatar
Anyone out there running the YSi with the G trim aftercooler by any chance?
doubt it but thought i'd ask..
Old Jun 12, 2006 | 09:04 PM
  #36
LS1Tech Co-Founder
I wouldn't. A T-Trim will even surpass the stock aftercooler IMO.
Old Jun 22, 2006 | 11:15 PM
  #37
69firebird's Avatar
anyone know how much the rmcr bracket is?
Thanks
Ed
