F1/F2 Procharger system...
Thanks
Thanks... I know there's not a "car kit" and I know there's a size difference but I thought somebody would have fabricated something by now... I'm looking for 20-30 lbs of boost and a cog system is a must...
Sand car application. I'm just looking to see if it's feasible. (I'm looking for another engine package to offer) If I knew how to post a pic on this board I'd show you guys what I need it for... But I don't know how. Sorry.
OK... So there's no cog system. What's the next best rib belt Procharger system and what kind of boost can I expect? (It has to mount on the passenger side of the engine. (That's where I have the most room)
Twin turbo systems are a dime a dozen @ the dunes... The only place they work really well is at the drags. A good running N/A V8 will run away and hide from a twin turbo V8 out in the dunes. BUT a belt driven compressor just might do the trick. And a "ready made kit" would keep the cost down and not be an issue on turn around time.... Come on venders... Speak up.
Thanks... I did contact them. <(email) They said they had nothing but problem with their cog system until the day they took it off. They do have a new belt system so I'm going to check that out.
Thanks again!
Also, can you lay out some of the twin turbo combo's? I guess I don't get how an N/A motor will beat a twin setup. Do the turbo rails have too much power? Poorly sized turbo's maybe?
I saw that set-up... That is a kit I'm thinking about. Thanks!
Turbo's have more power but the lag is a killer in the bowels. I've driven them and I've dune-d with other V8 cars that had them... And "for me" I wouldn't have one. By the time the power comes up it's time to turn... Then repeat the process over and over. Instant on and off power works the best.
Just my 2-cents.
I agree. Everybody I've talked to has steered me away from the cog system... I think I'm going to try the 10 rib system from ECS first and see how that goes... And all my cranks are from Callies and are keys for ATI dampener's... No pins are necessary.
Thanks for all the scooby!!!!
Jay
Just my 2-cents.
Have you called any sponsors to get quotes to fab up something?
No. Turbo size does not matter... It's just the way it is.
Jay
If your're not running a PolyChain then disregard, but the backside ribs are a giveaway without seeing the part number.
