Things they don't tell you about the 2/3 Bar OS ...and preliminary results inside
Originally Posted by FormulaFire
Do they have a 2/3 bar that'll work for the 98s? And what did you do to convert over to 3 bar?
http://www.hptuners.com/help/demos/2%20bar%20sd.swf
Tiago...looks like it's gonna be NASTY! Great info I will be considering while we're putting the final touches on the SS...put some damn injectors in there at let it EAT!! We'll be talking soon...Dallas here we come!!
Thanks guys, here is a little vid I made of yesterday's activities:
Right click and save as:
http://www.force-fed-fabrications.co...os/740dyno.wmv
#32
Originally Posted by NA$TY-TA
Bad *** man...... You going to try and keep pushing it on pump or add some race gas in there and see what ya can do????
I wont turn it up any mroe on pump gas. It makes enough power for pump, more then I asked for Just need to correct the knock sensor issue and trim up the timing a bit and the low boost tune will be done. For high boost I plan on running 109 only, maybe a 50% mix with C16, don't want to run 100% C16, O2 sensors and Wastegates might hate life
#35
Originally Posted by onfire
If your pumps will handle it, the Mototrons will handle much more pressure to get your DC down.....they've hit 1000rwhp on a dynojet at high fuel pressures.
So you have some safety margin while you're shopping for new injectors.
Rick
#36
Originally Posted by 2001-WS6
The Mototrons are used in off shore racing at 100psi. If your pump(s) can keep up, they can handle that much when boost refrenced in the car too.
Rick
Rick
they are fine at 72 psi right now, fuull boost referenced, I need to find a pump curve to see what they woudl do at higher pressure
#39
After talking to Jim @ speed inc. BTW Jim thanks for your time and insight. Those injectors are at their max. Sorry beat you guys to the punch those 60's are mine . Theyll work well with the additional methanol for me. The readings of which tiago spoke of were correct they were at 190% duty cycle pushing at 41m/sec on the injector reading.....Well at least after finishing this car mine will be a walk in the park in reference to finishing up my tune. Also Tiago did you let anyone know your best mod ........those stock tires on the back......you said they did not spin and the graph did not show it I not sure how though.
Originally Posted by Tiago
Im running twin WAlbro's intank, with stock wiring
