anyone try this for a crankcase evac set up?
. normally racecar stuff because it will make oil smoke. It can pull too much as well, alot depends on the placement On astreet car with ANY kind of backpressure, it will not work.
since i am pulling from the baffeled vent on the valve cover i dont think it will pull much if any oil out of the motor. i use about 1 quart every 2000miles, that might seem like a lot but i am out there beating the hell out of a 1000rwhp motor. it is going to use a little oil isn't it?
just like i posted a few posts up. it works good at idle and cruse. there are no vapors or smells coming out from under my hood or the vent filter i have. under the truck there is some oil residue so it must be letting some vapor out at wot. the vacume line i have going to the exhaust vent is prety small and long. it might work at wot better with a larger line but i didn't want to tap into the valve cover in a place with no baffle. i might try spliting off a few smaller lines taped under the same baffle and y them into the larger line on the oneway valve.
Please, others with real experience chime in with updates!
I have a 3" downpipe and 3" exhaust all the way out the back. I have not tested it with the cutout open yet but i'm sure it is better.
