anyone try this for a crankcase evac set up?
Old Jul 23, 2006 | 09:14 PM
  #41
MiaSSmaro98's Avatar
awesome can u post pics of ur setup
Old Jul 23, 2006 | 11:22 PM
  #42
parish8's Avatar
single digit dreamer
here are a couple of pics. i forgot to resize them so they are kinda big.
http://www.neufamily.org/images/IMG_2554.JPG
http://www.neufamily.org/images/IMG_2555.JPG
Old Jul 24, 2006 | 02:28 PM
  #43
so u have the evac on pass cover on the breather on drive side cover thats it?no catch can or check vavles?also do u have one or two ports on ur pass cover?
Old Jul 24, 2006 | 05:05 PM
  #44
parish8's Avatar
thats all i have. i dont see any reason to catch the oil if it is just going to send it out my tail pipe. there is one "port" on my pasenger cover, i just adapted it to the 5/8" hose going to the evac.
Old Jul 24, 2006 | 07:17 PM
  #45
yeah fbody with center bolt covers have 2 port on the pass cover,so its been working for you cool congrats do u think it work for running like a loudmouth muffler and 3 inch downpipe?
Old Jul 24, 2006 | 09:02 PM
  #46
67Firebird455's Avatar
No different than the evac system I use on the 67.
Old Jul 24, 2006 | 09:18 PM
  #47
i dont know if to use this setup or the breather/catch can setup
Old Jul 25, 2006 | 02:53 AM
  #48
under pressure's Avatar
Default evac tube on downpipe
I have run this setup on my turbo Buick several years ago and it seemed to work very well. I noticed that the blowby mess on my valve cover breathers went away immediately. Mac
Old Jul 25, 2006 | 08:15 AM
  #49
TT402LS1's Avatar
Nice set up Parish! Im running Speed Inc. valve covers w/ Billet Specialties breathers. (non PVC types) I was thinking of plumbing a hose from the lifter vally cover ( I think theres room behind my LS6 intake) to my DP. Maybe a larger hole w/ a Y or T to both DP's. Do you think this would work the same? I could also run a catch can w/ a breather if needed. Thanks - Ron
P.S. This is a twin turbo setup.
Old Jul 25, 2006 | 01:27 PM
  #50
AKAFRED's Avatar
how much oil are you loosing thru this? could this be run before a 3" cat?
Old Jul 25, 2006 | 01:31 PM
  #51
Superado's Avatar
11 Second Truck Club
I'm glad you've put this to the test...I posted this same type set-up in another pcv thread...but no response from anyone...it was the last post to another on-going pcv thread...
https://ls1tech.com/forums/showthrea...9&page=4&pp=20
Parish...I just added a breather to my passenger side vc, replacing the fill tube and cap...I could do the same evac set-up from the pcv location that you have your breather...correct? Not sure what fitting I would use to replace the pcv valve...
Also, where did you get the angle cut fitting...it seems relatively easy to fab if not available individually...
Old Jul 25, 2006 | 01:32 PM
  #52
parish8's Avatar
the motor only has about 400miles on it so far so i can't say for sure but i am tied into the stock vent tube on the valve cover and it has the factory baffles built into it. i would be suprized if i lost much oil.
not sure how the cat would like the small amount of oil vapor that it did see.
Old Jul 25, 2006 | 01:35 PM
  #53
parish8's Avatar
the fitting and one way valve came from summit. you can get a plastic fitting with threads on one side and a 90deg hose barb on the other and it will thread right into the rubber gromet that the pcv came out of.
Old Jul 25, 2006 | 01:51 PM
  #54
Superado's Avatar
thanks Parish...I may have to do this when installing my catless y-pipe...
did you just cap off the existing pcv vacuum line?
the one you used for the evac was originally going to TB?
Old Jul 25, 2006 | 02:56 PM
  #55
parish8's Avatar
yep, i think i used that vacume port that was the pcv to goto a hobs for my 2nd fuel pump so yea, just cap it. and yet i tied the evac into the line that used to goto the tb.
Old Jul 25, 2006 | 03:05 PM
  #56
Superado's Avatar
good deal...thanks again for the info...just wanted to make sure we were both singing from the same sheet of music...if there is a "good-better-best" vacuum source for the boost gauge, I would think the pcv line from the rear would be best, so I may just move my boost gauge to there instead of capping it...it is t'd off of fuel regulator and surge valve currently...
Old Jul 25, 2006 | 05:25 PM
  #57
Superado's Avatar
just FYI...anyone interested in these parts...
Summit MOR-97800 Moroso Replacement Check Valves $19.69ea
Summit MOR-97810 Moroso Replacement Weld-In Nipple Fittings $10.99ea
Parish, do you think that the oil separator/breather that comes w/ the complete kit, but also sold separately like the items above would be neccessary...or just the 90 as you stated?
Old Jul 25, 2006 | 06:36 PM
  #58
parish8's Avatar
i dont see needing it since we are tieing into parts of the valve cover that have a factory baffle.
Old Jul 25, 2006 | 06:43 PM
  #59
JMBLOWNWS6's Avatar
Yup a simple venturi effect. Might try that. Dunno!
Old Jul 25, 2006 | 06:54 PM
  #60
Project GatTagO's Avatar
Sure doesn't seem like the venturi effect....
http://en.wikipedia.org/wiki/Venturi_effect
Andrew
