Boost Reference
Old Jun 14, 2006 | 12:09 AM
JerikSS's Avatar
Default Boost Reference
I have a 5lb spring in my wastegate, and I am going to run an electronic boost controller, when everything is installed, when I turn on the boost controller will it be at 5psi or will there be some guess work involved???
Old Jun 14, 2006 | 12:13 AM
2002/Black/SS's Avatar
depends on the type of boost controller, also u really have a 232/228 cam? i might be wrong but dosent a 228/232 sound better?
Old Jun 14, 2006 | 01:51 AM
JerikSS's Avatar
its a profec b spec 2, if it helps dont want to overboost.
Old Jun 14, 2006 | 07:34 AM
Ping King's Avatar
reverse splits are good for turbos.
Old Jun 14, 2006 | 03:52 PM
JerikSS's Avatar
Like ping king, i was under the impression that reverse split cams were better for turbos........i am fairly new so i might be totally wrong.
Old Jun 14, 2006 | 03:57 PM
MECHAM's Avatar
when u hook up the BC...and u turn the boost off/down to the lowest setting (for my Eboost this would be setting 00)...it will go off the WG spring 5psi in yr case.
the profect should have a instructions manual right? also im under the impressuon that the profec when it is first started up puts boost to 0 automaticly, so ur boost will be wtvr ur spring is set for also the profec should have a mas boost limiter that u can set for safety
Old Jun 14, 2006 | 04:04 PM
JerikSS's Avatar
so if the profec b puts it to 0 and my wastegate has a 5lb spring, i will have to just add 3lbs on the profect to come to 8lbs of total boost, am i right?
Old Jun 14, 2006 | 04:07 PM
MECHAM's Avatar
no..u would set the BC to 8psi...
cause anything less than 5psi you dial in on the BC will be negated by the WG spring 5psi.
Old Jun 14, 2006 | 04:35 PM
JerikSS's Avatar
so my limit of how low i could go would be 5lbs due to the spring...i get it thaks guys
