got an idea....
Old Jun 17, 2006 | 12:18 AM
obZidian's Avatar
Default got an idea....
Ppl have been using stock manifolds in custom turbo kits. They usually are pointing foward and down. This is good on the driver side but on the passenger side, this setup will take cause you to delete your AC.
What if, instead of swaping the manifolds from banks and installing them foward... why not just keep them on the same bank and invert them, so that the exhaust side is facing foward but upwards.
Will this upward flowing manifold and piping have enough clearance to keep your AC, for example? My deal is that i want to keep AC since miami is either a freak frying pan when hot, not like arisone hot but hot a humid, you guys from the lakes know what i mean, or its raining, then the sun comes out and heats uop again nasty.
So can this be done? Or just another one of my "ideas"?
Old Jun 17, 2006 | 02:10 AM
chuntington101's Avatar
i have seen a classic built with cast manifolds turned upside down and it looked good!
but some guys said that there would't clear the shock towers!
good idea though
Old Jun 17, 2006 | 10:13 AM
smokinHawk's Avatar
yes i have tried to fit them like that and they wont clear the shock towers, they just wont fit
Old Jun 17, 2006 | 10:15 AM
Boostaholic's Avatar
Have you considered keeping the passanger side one on normal and the driver side (another passanger side one) flipped then making a pipe that crosses down under and comes forward along the drivers side?
We did that with a LT1
Old Jun 18, 2006 | 02:31 AM
obZidian's Avatar
right, had that in mind....... basically the crossover pipe would cross over under the trans, turn foward towards the turbo mounted in fron of driver side and joined to the driver side to turbo flange.
Can you get this cross over to go over the trans? Dont think so but... anyways, will this long crossover tube cause any ill affects with boost response? What is a possible fix? USe a smaller pipe for the crossover to increase exhaust pressure to turbo, will this help or be more of a restriction?
thanks ya'll!
Old Jun 19, 2006 | 03:29 AM
red90cobra's Avatar
2.5 inch pipe is all you need as far as cross over till you get to a merge to the turbo
Old Jun 19, 2006 | 03:33 AM
We used a 2.5in pipe with no problems on a LT1, boost response was instant with our single T70.
You wont be able to go over the trans if I had to guess, but there should be room someplace down there to cross over if you get under your truck and look at it.
Old Jun 19, 2006 | 04:17 AM
red90cobra's Avatar
if its an auto you can just go under by the converter. a t56 would be a little harder
Old Jun 19, 2006 | 06:39 AM
bboyferal's Avatar
My crossover goes over the trans... But mine doesn't use stock manifolds...
Old Jun 19, 2006 | 08:54 AM
Toonz's Avatar
Anyone have any pics of the "one flipped, one normal" setup? That seems pretty cool if done right.
Old Jun 19, 2006 | 10:49 AM
smokinHawk's Avatar
i had some with the engine out, somewhere but cant find them, but couldnt get any in the car cause they just wont fit, unless a hammer came out or something like that.
Old Jun 19, 2006 | 11:49 AM
RICE ETR's Avatar
Turbo Addict
Still running A/C.....
I've got a stock '98 pass side manifold on my driver side and a stock '01 pass side manifold on my passenger side.
Driver side points down and forward, passenger side is in stock location. All of my piping is above the k-member thanks to the tubular k-member.
I have another set of manifolds that will cut the distance in half that my passenger side has to go do the loop and also allow me to keep my altenator in the stock location....so i think.
Old Jun 19, 2006 | 12:38 PM
red90cobra's Avatar
really good idea.
Old Jun 19, 2006 | 09:33 PM
obZidian's Avatar
RICE ETR: nice, you did your own welding or had a shop do that for ya? I haven't welded either but i have a mig welder hanging around. If stainless, i figure i need a tig welder and practice!! You guys think coating the pipes going by the starter/starter solenoid or warping those pipes to avoid any starter/heat issues?
Here's another, how about a PTS kit with a t88 turbo, can that be done? Maybe with an aftermarket radiator mved a bit foward?
How about those twin speedinc kits, those retain A/C?
Old Jun 19, 2006 | 10:07 PM
bboyferal's Avatar
Man, I don't know about anything with a T-88 keeping A/C... Good question.
With the T-76, the stock radiator does not have to be moved and everything fits fine.
Speed inc has a twin kit now? TTi?
Old Jun 20, 2006 | 06:14 PM
bigturboz28's Avatar
I routed mine in front with a GT42 (pretty big cold side), without moving the rad (it sits where an ATI procharger does). I used edelbrock headers (were on the car when purchased) both installed as if NA, then ran two tubes under the K-Member and up in front of the rad, everything fits ok, and very little ground clearence issues.
Old Jun 20, 2006 | 07:30 PM
RICE ETR's Avatar
Turbo Addict
Thanks Red90cobra
Thanks....yes i did my own welding..with a mask that was too dark....those two combined make for horrible welds
I don't think there are any issues with heat and the starter.....i'm still running the original.
Old Jun 20, 2006 | 10:27 PM
Reject's Avatar
holy crap i was having those EXACT same idea's earlier today!
Old Jun 21, 2006 | 10:05 AM
CHRISPY's Avatar
Can you post pics of your setup for us to see?
Old Jun 21, 2006 | 10:38 AM
Reject's Avatar
yeah me too! i'd like to check it out
